[Qgis-user] Looking for a suggestion on a vector format
Randal Hale
rjhale at northrivergeographic.com
Fri Dec 18 07:01:36 PST 2015
Ye gads...
Well....I would say no to shapefiles.
Spatialite would work - probably postgis would be better.
You could contain your project in one QGIS File - for instance I'm story
an entire project in postgis and am retrieving various components
through about 20 qgs files. All the annotation etc is stored in the qgs
file, all labels, line colors, and map layouts. All the data is stored
in PostGIS.
Of course that's a much larger discussion than my simple few sentences -
but I think if you want everything stand alone.....eh - it's going to
have to be at least two components or QGIS/<file format> of some sort. I
think there will always be some external querying (be it automatic or
manual)....of I'm understanding it all correctly.
...and I just looked at your example and that's a head scratcher. I
think QGIS with Atlas to pull from the database automatically maybe a
better train of thought.
I just wanted to say Good Luck, We're all counting on you.
Randy
On 12/18/2015 09:14 AM, Jesse McGraw wrote:
> All,
> Before I go too far down the wrong path perhaps you can help me with
> a suggestion on a vector format to use for a project of mine:
> I'm to looking to basically re-create various Instrument Approach
> Procedure plates (see here
> <http://aeronav.faa.gov/d-tpp/1513/00375il28r.pdf> for an example for
> San Francisco International - SFO ) from a database via a perl script
> and display a number of them as vector overlays in an existing QGIS
> project
> What would be a good format to use for this purpose?
> I'm imagining something like a QGIS project file, but I want it to
> contain to contain all of the various bits of information internally
> (coordinates, names, styling, icons etc.) and not have to query
> anything external so each file is a stand-alone unit.
> Ideally all of the coordinates would be real world lon/lat so no
> transformation would be required. Bonus points if the format is
> openly standardized and easy to work with
> DWG/DXF? SVG?
> Thanks,
> Jesse
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151218/8f1f8064/attachment.html>
