[Qgis-user] Looking for a suggestion on a vector format
Jesse McGraw jlmcgraw at gmail.com
Fri Dec 18 08:33:05 PST 2015
Even though I'd prefer one file per procedure, a QGIS project + a
database would probably be an acceptable compromise.
However, how could I then add that new project file to an existing
project as a new layer?  Is there a concept in QGIS of sub projects?
On 12/18/2015 10:01 AM, Randal Hale wrote:
> Ye gads...
> Well....I would say no to shapefiles.
> Spatialite would work - probably postgis would be better.
> You could contain your project in one QGIS File - for instance I'm
> story an entire project in postgis and am retrieving various
> components through about 20 qgs files. All the annotation etc is
> stored in the qgs file, all labels, line colors, and map layouts. All
> the data is stored in PostGIS.
> Of course that's a much larger discussion than my simple few sentences
> - but I think if you want everything stand alone.....eh - it's going
> to have to be at least two components or QGIS/<file format> of some
> sort. I think there will always be some external querying (be it
> automatic or manual)....of I'm understanding it all correctly.
> ...and I just looked at your example and that's a head scratcher. I
> think QGIS with Atlas to pull from the database automatically maybe a
> better train of thought.
> I just wanted to say Good Luck, We're all counting on you.
> Randy
> On 12/18/2015 09:14 AM, Jesse McGraw wrote:
>> All,
>>   Before I go too far down the wrong path perhaps you can help me
>> with a suggestion on a vector format to use for a project of mine:
>> I'm to looking to basically re-create various Instrument Approach
>> Procedure plates (see here
>> <http://aeronav.faa.gov/d-tpp/1513/00375il28r.pdf> for an example for
>> San Francisco International - SFO ) from a database via a perl script
>> and display a number of them as vector overlays in an existing QGIS
>> project
>> What would be a good format to use for this purpose?
>> I'm imagining something like a QGIS project file, but I want it to
>> contain to contain all of the various bits of information internally
>> (coordinates, names, styling, icons etc.) and not have to query
>> anything external so each file is a stand-alone unit.
>> Ideally all of the coordinates would be real world lon/lat so no
>> transformation would be required.  Bonus points if the format is
>> openly standardized and easy to work with
>> DWG/DXF?  SVG?
>> Thanks,
>>   Jesse
>> Qgis-user mailing list
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com
> twitter:rjhalehttp://about.me/rjhale
> http://www.northrivergeographic.com/introduction-to-quantum-gis
> Southeast OSGEO:http://wiki.osgeo.org/wiki/Southeast_US
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151218/88f2ebcf/attachment.html>
