[Qgis-user] Errors when re-opening new installation of QGIS
Richard Duivenvoorde rdmailings at duif.net
Wed Jan 14 08:32:48 PST 2015
On 14-01-15 17:18, Andre Joost wrote:
> You see a version number that the plugin manager can not handle.
> Timlinux has issued today a new version 2.2.3:
> https://plugins.qgis.org/plugins/inasafe/version/2.2.3/
> with a Maximum QGIS version of 2.99.0
> So everything should be safe now.
Tim can you confirm this? Upon retrieving of the new plugin.xml this is
ok? Or is it still a problem when you have the plugin locally installed?
Should this be fixed in the plugin manager also? Bad metadata should not
be able to break QGIS or the plugin manager?
Regards,
