[Qgis-user] Problem using gdal_grid interpolation (Nicolas Cadieux)
Ferruccio Sarra ferruccio.sarra at gmail.com
Fri Jul 10 12:22:28 PDT 2015
Hi Nicolas,
I used the Grid (interpolation) function via the raster menu.
Anyway I rebooted Qgis and now it interpolates properly (same sample layer
within the same .qgs file). Maybe my mistake somehow...
Thank you and sorry to waste your time.
Cheers,
Fer
> Message: 3
> Date: Wed, 8 Jul 2015 20:44:37 +0200
> From: Ferruccio Sarra <ferruccio.sarra at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Problem using gdal_grid interpolation
> Message-ID:
>         <CAMKLSQG_FUaxEq=
> zvgfcD54sFpe+J3ZOswOCYQRQeftD1fH-zw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi all,
> I am new to Qgis. Can I count on someone help!?
> While using a Grid (Interpolation) algorithm... "The process failed to
> start. Either the invoked program is missing, or you may have insufficient
> permissions to invoke the program".
> A similar problem have been arisen for Mac OSX (qgis-user mailing list
> archive).
> Any clue for a a Qgis 2.8.1 installation on Fedora 21? (I have just
> followed the step by step installation guide on qgis site).
> Thanx,
>  Fer
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20150708/b7842541/attachment-0001.html
> Message: 4
> Date: Wed, 8 Jul 2015 11:51:48 -0700 (PDT)
> From: Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> Subject: Re: [Qgis-user] Problem using gdal_grid interpolation
> Message-ID: <d5e6b553-415b-4313-8ff1-1d326ea5b213 at email.android.com>
> Hi,
> Are you using gdal-grid via the raster menu or the via the processing
> plugin.  Post the command you used here.
> It is possible you have an extra space or character in the command.  Are
> you modifying the command or letting QGIS writing it for you?
> You can also trouble shot by copying the command ( if you are using it via
> the raster menu) and copying it directly at the command prompt.  If you add
> "--debug on" you will get more info.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Jul 8, 2015 14:40, "Ferruccio Sarra-2 [via OSGeo.org]   " &
> lt;ml-node+s1560n5214926h67 at n6.nabble.com> wrote:
> Hi all, I am new to Qgis. Can I count on someone help!?? While using a
> Grid (Interpolation) algorithm... "The process failed to start. Either
> the invoked program is missing, or you may have insufficient permissions to
> invoke the program". A similar problem have been arisen for Mac OSX
> (qgis-user mailing list archive). Any clue for a?a Qgis 2.8.1?installation
> on Fedora 21? (I have just followed the step by step installation guide on
> qgis site). Thanx, ?Fer?
> Qgis-user mailing list
> [hidden email]
>                 If you reply to this email, your message will be added to
> the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Problem-using-gdal-grid-interpolation-tp5214926.html
>                 To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com
>                 To unsubscribe from Quantum GIS - User, click here .
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Problem-using-gdal-grid-interpolation-tp5214926p5214929.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20150708/b36472b2/attachment-0001.html
> End of Qgis-user Digest, Vol 113, Issue 21
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/9ef05893/attachment.html>
