[Qgis-user] VIIRS geolocation data
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 8 14:01:25 PDT 2015
Welcome to QGIS!
You will probably enjoy the semi-Automatic Classification Plugin then!
You can also look at Opticks
http://opticks.org/confluence/display/opticks/Welcome+To+Opticks
I have not used the VIIRS data but have you tried using the GDAL
Georeferencer plugin? If you have coordinates of all 4 corners, it
should be easy to do. Be careful of the chosen algorithm unless you
don't mind changing the data.
Also, you can try using a world file if you first export it to a .tiff
(Raster/conversion/Translate)
This is was a test.tiffw wold file looks like. It would georeference
test.tiff if found in the same directory.
0.00185013204225353
0
0
-0.00185013204225353
-74.04486388644366457
46.02451243397887737
Go here for more information.
http://en.wikipedia.org/wiki/World_file
Hope this helps
Nicolas Cadieux
Le 2015-05-08 16:13, Dr. Mitchell Andrew Schull [via OSGeo.org] a écrit :
> Hi all,
> I’m a new qGIS user (yesterday). I’m trying to find a good ENVI
> replacement and it seems like qGIS is pretty good. One of the nice
> features is the ability to quickly map your data on Google Earth
> without having to create a KML via GEarth_View. Unfortunately if your
> data is not properly referenced it doesn’t work. That all being said I
> am running into the issue where I can open VIIRS data which is awesome
> however even though it has Lat and Lon info given as separate layers
> in the H5 product there doesn’t seem to be a way to add it to the file
> and possibly create a geotiff. Of course then I cannot use Google
> Earth. I would also like to overlap imagery for analysis so its
> annoying. Any ideas? Anybody wrote a plugin for this?
> Thanks
> Mitch
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5204898&i=0>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/VIIRS-geolocation-data-tp5204898.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/VIIRS-geolocation-data-tp5204898p5204900.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150508/f8ac6a9e/attachment.html>
