[Qgis-user] VIIRS geolocation data
Noli Sicad
nsicad at gmail.com
Fri May 8 17:16:00 PDT 2015
Hi Mitch,
For ENVI replacement, install QGIS OTB Plugin, then have a look at the
"Processing" in the menu.
Here's an example,
http://opensourcegisblog.blogspot.com.au/2014/08/image-processing-using-orfeo-toolbox-in.html
Noli
On 5/9/15, Dr. Mitchell Andrew Schull <mitch.schull at noaa.gov> wrote:
> Hi all,
> I’m a new qGIS user (yesterday). I’m trying to find a good ENVI replacement
> and it seems like qGIS is pretty good. One of the nice features is the
> ability to quickly map your data on Google Earth without having to create a
> KML via GEarth_View. Unfortunately if your data is not properly referenced
> it doesn’t work. That all being said I am running into the issue where I can
> open VIIRS data which is awesome however even though it has Lat and Lon info
> given as separate layers in the H5 product there doesn’t seem to be a way to
> add it to the file and possibly create a geotiff. Of course then I cannot
> use Google Earth. I would also like to overlap imagery for analysis so its
> annoying. Any ideas? Anybody wrote a plugin for this?
> Thanks
> Mitch
