[Qgis-user] OSGeo4W's QGIS Web Server install problem. “Not Found ... qgis_mapserv.fcgi”
Frank Sokolic sokolic at worldonline.co.za
Fri May 8 23:55:32 PDT 2015
Hi Dennis,
Did you actually rename "qgis_mapserver.fgci.exe" to remove the ".exe"
extension? If not, try this as it worked for me.
Regards, Frank.
On 08/05/2015 21:16, dennis mckay wrote:
> I have been spending days trying to start the “Apache OSGeo4W Web Server” on a Win7 Professional SP 1.  I have no experience with Apache.  I have followed the tutorial steps from the QGIS Web Server wiki and Anita Graser's how-to and also other forum advice.  This has led me to upgrading from QGIS 2.4 to 2.6, then to QGIS 2.6 64bit.  Lastly I upgraded Apache from 2.2 32bit to 2.4 64bit.  I finally get “It works!” from localhost/ using any combination of 32/64bit QGIS or Apache.  Trying “http://localhost/OSGeo4W64/apps/qgis/bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities” results in  “Not Found  The requested URL /OSGeo4W/apps/qgis/bin/qgis_mapserv.fcgi was not found on this server.”   This is the error I get no matter what the combination of Apache and QGIS installs – and regardless of including “.exe” with the file name.
> Some recommended actions I took may be obsolete with QGIS 2.6 or Apache 2.4.  I am trying to reduce my variables here and need help focusing on where the problems are:  The major adaptations I did, beyond updating .conf files to new Apache 2.4 format were:
> 1) Disabling references to fcgid and replacing them with cgi (in .conf files).  On newer forum advice, I reverted back to fcgi.
> 2) Replacing backslashes with forward in file names as per Apache admonitions.  My confusion: original osgeo installs and forum examples have hybrid examples like "C:\OSGeo4W/apps/ka-map-1.0".  Always with the backslash after C: and no documentation in sight as to the advantages of doing this, if any.
> 3) Following a forum advice to copy files from apps\Python27\Lib to apps\qgis\bin.
> 4) Upgrading to 64 bit Apache required copying application-specific .conf files from OSGeo4W\httpd.d directory to OSGeo4W64\httpd.d and updating the terminology.
> 5) In the URL for qgis_mapserver.fgci.exe, replacing “localhost” with 127.0.0.1 or with my machine's tcp/ip #.
> 6) Using the latest version of mod_fcgid.so from Apache lounge.
> Variables in httpd.conf appear to point to the correct directories/files.  I think relevant settings are:
> ServerRoot "C:/OSGeo4W64/Apache24"
> ServerName  ###.###.#.#:80      [my “IPv4 Address” has real numbers not seen here ]
> DocumentRoot "C:/OSGeo4W64/Apache24/htdocs"
> ScriptAlias /cgi-bin/ "C:/OSGeo4W64/apps/Python27/Lib/"    [this is new location for cgi.py,etc.]
> DirectoryIndex index.html index.html.var index.php index.phtml index.php3
> Alias /ms_tmp/ "C:/OSGeo4W64/tmp/ms_tmp/"
> “Require all denied” on:
>     Directory “/”
>     FilesMatch “\.ht”
> “Require all granted” on:
>     Directory "C:/OSGeo4W64/Apache24/htdocs"                       [DocumentRoot]
>          Options Indexes FollowSymLinks Includes
>     Directory “C:/OSGeo4W64/apps/Python27/Lib”                    [ScriptAlias /cgi-bin/ ]
>           Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
>           SetEnv LD_LIBRARY_PATH "C:/OSGeo4W64/lib"
>     Directory “C:/OSGeo4W64/tmp”                                              [ /tmp/ ]
>     Directory “C:/OSGeo4W64/apps/qgis/bin”                               [ /qgis/ ]
>           SetHandler fcgid-script
>           Options ExecCGI
> AddHandler cgi-script .cgi
> AddType application/x-httpd-php .php5 .php4 .php3 .phtml .php
> Action  application/x-httpd-php "C:/OSGeo4W64/apache24/htdocs"
> Include conf/extra/httpd-autoindex.conf
> Include conf/extra/httpd-manual.conf
> Include "C:/OSGeo4W64/httpd.d/httpd_*.conf"
> SetEnv PROJ_LIB "C:/OSGeo4W64/share/proj"
> SetEnv PATH "C:/OSGeo4W64/bin"
> SetEnv GDAL_DATA "C:/OSGeo4W64/share/gdal"
> SetEnv GDAL_DRIVER_PATH "C:/OSGeo4W64/bin/gdalplugins"
> SetEnv TMP "C:/OSGeo4W64/tmp"
> SetEnv MS_ERRORFILE "C:/OSGeo4W64/tmp/ms_error.txt"
> SetEnv MS_DEBUGLEVEL 3
> Question:  Does qgis_mapserv.fgci.exe return good debugging info if run from command line?
> Question:  What is the format for passing parameters to qgis_mapserv.fgci.exe in the command line?
> Question:  In Apache .conf files, can quotes in path names be dropped if there are no spaces?
> The Real Question:  Why does my browser not find qgis_mapserver.fgci.exe?
> I am grasping for clues that a seasoned eye would see.  Dennis
> Qgis-user mailing list
