[Qgis-user] OSGeo4W's QGIS Web Server install problem. “Not Found ... qgis_mapserv.fcgi”
Mats Elfström mats.elfstrom at gmail.com
Sat May 9 01:20:37 PDT 2015
Hi alla!
I have also spent far too much time trying to find a working combination of
postgis/qgis/qgis server.
I confess I haven't yet tried all possible permutations, but have more or
less given up.
Why do we have to put up with thsi sorry state of things?
Will somebody with a working installation on a Windows 2012 64 bit server
please step forward and tell us how to do it.
Regards, Mats.E
2015-05-09 8:55 GMT+02:00 Frank Sokolic <sokolic at worldonline.co.za>:
> Hi Dennis,
> Did you actually rename "qgis_mapserver.fgci.exe" to remove the ".exe"
> extension? If not, try this as it worked for me.
> Regards, Frank.
> On 08/05/2015 21:16, dennis mckay wrote:
>> I have been spending days trying to start the “Apache OSGeo4W Web Server”
>> on a Win7 Professional SP 1.  I have no experience with Apache.  I have
>> followed the tutorial steps from the QGIS Web Server wiki and Anita
>> Graser's how-to and also other forum advice.  This has led me to upgrading
>> from QGIS 2.4 to 2.6, then to QGIS 2.6 64bit.  Lastly I upgraded Apache
>> from 2.2 32bit to 2.4 64bit.  I finally get “It works!” from localhost/
>> using any combination of 32/64bit QGIS or Apache.  Trying “
>> http://localhost/OSGeo4W64/apps/qgis/bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities”
>> results in  “Not Found  The requested URL
>> /OSGeo4W/apps/qgis/bin/qgis_mapserv.fcgi was not found on this server.”
>>  This is the error I get no matter what the combination of Apache and QGIS
>> installs – and regardless of including “.exe” with the file name.
>> Some recommended actions I took may be obsolete with QGIS 2.6 or Apache
>> 2.4.  I am trying to reduce my variables here and need help focusing on
>> where the problems are:  The major adaptations I did, beyond updating .conf
>> files to new Apache 2.4 format were:
>> 1) Disabling references to fcgid and replacing them with cgi (in .conf
>> files).  On newer forum advice, I reverted back to fcgi.
>> 2) Replacing backslashes with forward in file names as per Apache
>> admonitions.  My confusion: original osgeo installs and forum examples have
>> hybrid examples like "C:\OSGeo4W/apps/ka-map-1.0".  Always with the
>> backslash after C: and no documentation in sight as to the advantages of
>> doing this, if any.
>> 3) Following a forum advice to copy files from apps\Python27\Lib to
>> apps\qgis\bin.
>> 4) Upgrading to 64 bit Apache required copying application-specific .conf
>> files from OSGeo4W\httpd.d directory to OSGeo4W64\httpd.d and updating the
>> terminology.
>> 5) In the URL for qgis_mapserver.fgci.exe, replacing “localhost” with
>> 127.0.0.1 or with my machine's tcp/ip #.
>> 6) Using the latest version of mod_fcgid.so from Apache lounge.
>> Variables in httpd.conf appear to point to the correct
>> directories/files.  I think relevant settings are:
>> ServerRoot "C:/OSGeo4W64/Apache24"
>> ServerName  ###.###.#.#:80      [my “IPv4 Address” has real numbers not
>> seen here ]
>> DocumentRoot "C:/OSGeo4W64/Apache24/htdocs"
>> ScriptAlias /cgi-bin/ "C:/OSGeo4W64/apps/Python27/Lib/"    [this is new
>> location for cgi.py,etc.]
>> DirectoryIndex index.html index.html.var index.php index.phtml index.php3
>> Alias /ms_tmp/ "C:/OSGeo4W64/tmp/ms_tmp/"
>> “Require all denied” on:
>>     Directory “/”
>>     FilesMatch “\.ht”
>> “Require all granted” on:
>>     Directory "C:/OSGeo4W64/Apache24/htdocs"
>>  [DocumentRoot]
>>          Options Indexes FollowSymLinks Includes
>>     Directory “C:/OSGeo4W64/apps/Python27/Lib”
>> [ScriptAlias /cgi-bin/ ]
>>           Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
>>           SetEnv LD_LIBRARY_PATH "C:/OSGeo4W64/lib"
>>     Directory “C:/OSGeo4W64/tmp”
>>     [ /tmp/ ]
>>     Directory “C:/OSGeo4W64/apps/qgis/bin”
>>  [ /qgis/ ]
>>           SetHandler fcgid-script
>>           Options ExecCGI
>> AddHandler cgi-script .cgi
>> AddType application/x-httpd-php .php5 .php4 .php3 .phtml .php
>> Action  application/x-httpd-php "C:/OSGeo4W64/apache24/htdocs"
>> Include conf/extra/httpd-autoindex.conf
>> Include conf/extra/httpd-manual.conf
>> Include "C:/OSGeo4W64/httpd.d/httpd_*.conf"
>> SetEnv PROJ_LIB "C:/OSGeo4W64/share/proj"
>> SetEnv PATH "C:/OSGeo4W64/bin"
>> SetEnv GDAL_DATA "C:/OSGeo4W64/share/gdal"
>> SetEnv GDAL_DRIVER_PATH "C:/OSGeo4W64/bin/gdalplugins"
>> SetEnv TMP "C:/OSGeo4W64/tmp"
>> SetEnv MS_ERRORFILE "C:/OSGeo4W64/tmp/ms_error.txt"
>> SetEnv MS_DEBUGLEVEL 3
>> Question:  Does qgis_mapserv.fgci.exe return good debugging info if run
>> from command line?
>> Question:  What is the format for passing parameters to
>> qgis_mapserv.fgci.exe in the command line?
>> Question:  In Apache .conf files, can quotes in path names be dropped if
>> there are no spaces?
>> The Real Question:  Why does my browser not find qgis_mapserver.fgci.exe?
>> I am grasping for clues that a seasoned eye would see.  Dennis
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Mats Elfström, Väpplingvägen 21, SE-227 38 LUND, Sweden
tel: +46 46 145959 / mob: +46 70 595 39 35
alt e-mail: mats.elfstrom at giskraft.com <mats.elfstrom at telia.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150509/fd618c3f/attachment.html>
