[Qgis-user] Assistance with high-level use case of QGIS for commercial use
Dave Tobias terra2you at gmail.com
Wed Mar 2 10:44:27 PST 2016
Many thanks to James, Brent, Alexander and Andreas for the suggestions.  It
looks like PostGIS offers the best option for the limited complexity of the
solution.  PostGIS is not something I had worked with before or considered.
After doing a bit of research and referencing the code/process Brent
offered, I think we have our path forward.
Thanks again!
Dave
On Sun, Feb 28, 2016 at 6:38 AM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi Dave,
> If it is just the point-in-polygon overlay - then I believe QGIS server
> may be overkill for what you want. As others mentioned I would do a simple
> python Script and use GEOS or Postgis to do the overlay. You could create a
> microservice for that with the above mentioned tools.
> Most likely, QGIS server also would be slightly slower than GEOS or
> Postgis, for the overlay operation. However, if you insist on QGIS server,
> you could try with a WPS service or a QGIS server plugin. I believe there
> is an ongoing project to support QGIS processing models as a WPS service.
> So if you plan to add more such services in the future, you may want to
> explore this project (
> http://www.3liz.com/blog/rldhont/index.php?post/2015/09/07/wps4server%3A-QGIS-Processing-to-Web-Processing-Service
> Andreas
> On 26.02.2016 23:26, Dave Tobias wrote:
> I'm new to QGIS and have been a very long time user of a commercial GIS
> solution.  Their fee to deploy a mapservice has opened my eyes to other
> options.  I use the term mapservice loosely because what I want to deploy
> won't even have a map GUI.  It is quite simple actually:
> I would like to deploy QGIS such that multiple non--GIS users can use
> their individual secure logins to upload a .txt file (in a prescribed
> format) which will contain a feature ID, latitude and longitude coordinate
> for each row.  Then in batch mode, the program would then overlay the
> points with a polygon layer I maintain on that server. The output would be
> a .txt file containing the input attributes plus 1 attribute added to each
> row from the polygon layer. No map display needed, no other user
> interaction.  This is a simple geospatial operation for which they will pay
> a nominal fee.
> I was able to do this same operation manually with QGIS desktop and I see
> there is an API to perform the operation as a script.  So...are there any
> barriers to me doing this with QGIS/QGIS Server? Is there support for this
> use-case already? I searched but didn't come up with any concrete examples
> in the forums already - a few were interactive apps, but I need mine to run
> in batch mode.
> Thanks in advance - hopefully I'm sending to the correct forum!
> Qgis-user mailing listQgis-user at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160302/39c4c1dd/attachment.html>
