[Qgis-user] edge calculator
Emiliano Manzo emiliano.manzo at ethoikos.it
Thu Mar 3 07:44:03 PST 2016
Thank you for all your answer.
I’ll try to explain better my problem.
I have to polygons shapes file one for forest and one for open areas with differents polygons for every shape.
If i need to calculate the length of the border between this 2 shapes just the edge between forest and open areas is there any function in qgis or I need to calculate by hand?
Thank you again
Emiliano
> Il giorno 02/mar/2016, alle ore 17:07, Paulo van Breugel <p.vanbreugel at gmail.com> ha scritto:
> Not tested, but what about using the v.to.db function (grass function, does not seem to be available in the toolbox, but you could have a look at the GRASS tools addon).
> With this function you can upload category numbers of left and right area, to an attribute table of boundaries common for the areas. With the same function, you can also upload the length of a line (need to check if that works for boundaries as well, but I suspect it does). These two combined should provide what you need? Check out the manual page https://grass.osgeo.org/grass70/manuals/v.to.db.html <https://grass.osgeo.org/grass70/manuals/v.to.db.html> for details.
> Paulo
> On Wed, Mar 2, 2016 at 3:54 PM, Emiliano Manzo <emiliano.manzo at ethoikos.it <mailto:emiliano.manzo at ethoikos.it>> wrote:
> Hi to all,
> is anybody know how I can calculate the linear length between 2 polygons?
> I need to measure the length between 2 different shape file in particular I have a habitat map and I need to calculate edge between to different habitat type.
> Thank you
> Emiliano
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
Fondazione Ethoikos
Convento dell'Osservanza
53030 Radicondoli  (SI)
Italy
Stazione Eto-Ecologica di Corbaiola
Tel. +39 0577 793055
Fax +39 0577 793082
Questo messaggio può contenere informazioni riservate. Se chi lo riceve non è il destinatario (o ha ricevuto questo messaggio per errore) è pregato di segnalarlo al mittente  e  distruggere il messaggio stesso immediatamente. E' vietata la copia, la visione o la distribuzione di questo messaggio e dei suoi eventuali allegati, in qualsiasi forma e modo.
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160303/41b66390/attachment.html>
