[Qgis-user] QGIS webclient theme switcher print issue
Neumann, Andreas a.neumann at carto.net
Thu Mar 3 02:39:55 PST 2016
Hi Franceso,
It is probably this known issue: http://hub.qgis.org/issues/14321
Expect a fix for this soon at github.
I am a bit surprised it complains about Layer "Layername" and not
template name though. I would expect the latter.
Andreas
On 2016-03-03 11:32, Francesco Marigliano wrote:
> Hi all,
> I'm having problems with the print functionality of qgis webclient.
> Suppose that I made two prject: _a.qgs_ and _b.qgs. _Suppose that the projects have different layers and in both are defined different print templates.
> SCENARIO 1
> Following the address http://myhost/app.html?map=A.qgs the print feature works properly, but if I choose the B project from the theme switcher and I try to print, I get the error:
> Layer _"layername"_ does not exists
> SCENARIO 2
> Following the address http://myhost/app.html?map=B.qgs the print feature works properly, but if I choose the A project from the theme switcher and I try to print, I get the error:
> Thanks in advantage for the support.
> Cheers,
> F.
> [1]
> Questa e-mail รจ stata controllata per individuare virus con Avast antivirus.
> www.avast.com [1]
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Links:
[1] https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160303/291f5976/attachment.html>
