[Qgis-user] QGIS webclient theme switcher print issue
Francesco Marigliano f.marigliano.it at ieee.org
Thu Mar 3 02:41:30 PST 2016
Hi Andreas,
Here a working example:
http://com14av.geourba.it/app.html?map=/maps/com14av.qgs
F.
Il 03/03/2016 11:39, Neumann, Andreas ha scritto:
> Hi Franceso,
> It is probably this known issue: http://hub.qgis.org/issues/14321
> Expect a fix for this soon at github.
> I am a bit surprised it complains about Layer "Layername" and not
> template name though. I would expect the latter.
> Andreas
> On 2016-03-03 11:32, Francesco Marigliano wrote:
>> Hi all,
>> I'm having problems with the print functionality of qgis webclient.
>> Suppose that I made two prject: /a.qgs/ and /b.qgs. /Suppose that the
>> projects have different layers and in both are defined different
>> print templates.
>> *Scenario 1*
>> Following the address http://myhost/app.html?map=*a*.qgs the print
>> feature works properly, but if I choose the *b* project from the
>> theme switcher and I try to print, I get the error:
>> Layer /"layername"/ does not exists
>> *Scenario 2*
>> Following the address http://myhost/app.html?map=*b*.qgs the print
>> feature works properly, but if I choose the *a* project from the
>> Thanks in advantage for the support.
>> Cheers,
>> F.
>> Avast logo <https://www.avast.com/antivirus>
>> Questa e-mail è stata controllata per individuare virus con Avast
>> antivirus.
>> www.avast.com <https://www.avast.com/antivirus>
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160303/89ef4040/attachment.html>
