[Qgis-user] OpenGeo QGIS webappbuilder plugin error
Luigi Pirelli luipir at gmail.com
Fri Mar 4 05:21:06 PST 2016
Hi Hanlie
thank you for the tech info. You can downgrade Processing directly
from Plgin Manager.
In Boundless, before to release the Suite we pass a bunch of unit and
integration tests to check if all installed version (plugin, qgis,
geoserver and so on) correctly works together.
If a wrong Processing version has been distributed is a bug (i'm just
checking it). Or can be the problem related to a Processing version
that (for a limitated time window) was uploaded (in the official with
wrong min/max version compatibility).
the Processing version for 2.8.3 would be 2.10.x. btw I'm checking if
there are some packaging problem.
in a couple of weeks will be available the latest QGIS 2.14 LTR
packaged for the OpenGeo suite.
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 4 March 2016 at 14:00, Hanlie Pretorius <hanlie.pretorius at gmail.com> wrote:
> Thanks for helping.
> OpenGeo Suite version 4.8
> webappbuilder plugin version
> 0.1-20150803-745BF17B0B05A4BB9447E0899FCA2BB66AEAD4E
> processing plugin version 2.12.2
> For the last one the error message is:
> This plugin is incompatible with this version of QGIS
> Plugin designed for QGIS 2.12 - 2.99
> The OpenGeo QGIS version is 2.8.3, so I guess I should try replacing
> the processing viewer with version 2.10.3.
> https://plugins.qgis.org/plugins/processing/
> Will try that and let you know how it turns out.
> 2016-03-04 14:52 GMT+02:00, Luigi Pirelli <luipir at gmail.com>:
>> Hi Hanlie
>> glad you are learning OpenGeo
>> I would ask you more info about the problem
>> webappbuilder plugin version (from plugin manager)
>> and
>> processing plugin version (from plugin manager)
>> regards
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 4 March 2016 at 13:29, Hanlie Pretorius <hanlie.pretorius at gmail.com>
>> wrote:
>>> Hi,
>>> I'm working on Windows 8.1.
>>> I have downloaded and installed QGIS for OpenGeo and the webappbuilder
>>> plugin fails to load with the following error:
>>> Couldn't load plugin webappbuilder due to an error when calling its
>>> classFactory() method"
>>> All the information I could find on the web about this error have not
>>> helped me.
>>> In the Plugin Manager the Uninstall plugin and Reinstall plugin
>>> buttons are disabled. It shows a message:
>>> This plugin is broken
>>> cannot import name show_message_log
>>> I have uninstalled and reinstalled OpenGeo QGIS several times but it
>>> makes no difference.
>>> Does someone know how to fix this plugin? I would really like to use
>>> it to start learning how to use OpenGeo.
>>> Thanks
>>> Hanlie
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
