[Qgis-user] R in QGIS on OSX using Kyngchaos build
Pieter du Plooy pjduplooy at zpanelcp.com
Sat Mar 5 09:06:38 PST 2016
Hi William
I was in fact referring to Processing plugin.
I installed rgdal, but that did not make a difference.
Bye the way, if I can be presumptuous, when are you planning to release
2.14?
Pieter
On Sat, Mar 5, 2016 at 6:42 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> Sorry I didn't reply to your earlier email.
> I think it depends on how your scripts interact with R.  I have an R
> plugin for the GDAL framework.  I also have an R plugin for the GEOS
> framework, but that's for an old version of R.
> You can run R scripts from the Processing plugin, but I don't know how
> that links R and QGIS data unless it's through GDAL.
> There is also rpy2 for using R from python, supposed to be a simple instal
> with pip, but requires Xcode tools to compile.  I have a package for an old
> R version, but I could update it.
> > On Mar 5, 2016, at 6:28 AM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
> > Hi guys
> > I would like to use R scripts in  QGIS 2.12 from Kyngchaos and am unable
> to.
> > I have installed the R package from r-project, and all  dependencies.
> > When I run the R scripts that I have downloaded, I get the missing
> dependency problem.
> > How do I go about rectifying it?
> > Regards
> > Pieter
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160305/211bb026/attachment.html>
