[Qgis-user] R in QGIS on OSX using Kyngchaos build
William Kyngesburye woklist at kyngchaos.com
Sat Mar 5 09:55:05 PST 2016
I don't know what Processing needs to work with R.
I just posted QGIS 2.14.
> On Mar 5, 2016, at 11:06 AM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> Hi William
> I was in fact referring to Processing plugin.
> I installed rgdal, but that did not make a difference.
> Bye the way, if I can be presumptuous, when are you planning to release 2.14?
> Pieter
> On Sat, Mar 5, 2016 at 6:42 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Sorry I didn't reply to your earlier email.
> I think it depends on how your scripts interact with R.  I have an R plugin for the GDAL framework.  I also have an R plugin for the GEOS framework, but that's for an old version of R.
> You can run R scripts from the Processing plugin, but I don't know how that links R and QGIS data unless it's through GDAL.
> There is also rpy2 for using R from python, supposed to be a simple instal with pip, but requires Xcode tools to compile.  I have a package for an old R version, but I could update it.
> > On Mar 5, 2016, at 6:28 AM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> > Hi guys
> > I would like to use R scripts in  QGIS 2.12 from Kyngchaos and am unable to.
> > I have installed the R package from r-project, and all  dependencies.
> > When I run the R scripts that I have downloaded, I get the missing dependency problem.
> > How do I go about rectifying it?
> > Regards
> > Pieter
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
"We can die but once, and that once we must die.  To be always fearing, then, would not avert it, and would make life miserable."
- Tarzan, on death
