[Qgis-user] R in QGIS on OSX using Kyngchaos build
Pieter du Plooy pjduplooy at zpanelcp.com
Sat Mar 5 10:09:20 PST 2016
William
Thank you so very much for your hard work!
Pieter
On Sat, Mar 5, 2016 at 7:55 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> I don't know what Processing needs to work with R.
> I just posted QGIS 2.14.
> > On Mar 5, 2016, at 11:06 AM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
> > Hi William
> > I was in fact referring to Processing plugin.
> > I installed rgdal, but that did not make a difference.
> > Bye the way, if I can be presumptuous, when are you planning to release
> 2.14?
> > Pieter
> > On Sat, Mar 5, 2016 at 6:42 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > Sorry I didn't reply to your earlier email.
> > I think it depends on how your scripts interact with R.  I have an R
> plugin for the GDAL framework.  I also have an R plugin for the GEOS
> framework, but that's for an old version of R.
> > You can run R scripts from the Processing plugin, but I don't know how
> that links R and QGIS data unless it's through GDAL.
> > There is also rpy2 for using R from python, supposed to be a simple
> instal with pip, but requires Xcode tools to compile.  I have a package for
> an old R version, but I could update it.
> > > On Mar 5, 2016, at 6:28 AM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
> > > Hi guys
> > > I would like to use R scripts in  QGIS 2.12 from Kyngchaos and am
> unable to.
> > > I have installed the R package from r-project, and all  dependencies.
> > > When I run the R scripts that I have downloaded, I get the missing
> dependency problem.
> > > How do I go about rectifying it?
> > > Regards
> > > Pieter
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "Time is an illusion - lunchtime doubly so."
> > - Ford Prefect
> "We can die but once, and that once we must die.  To be always fearing,
> then, would not avert it, and would make life miserable."
> - Tarzan, on death
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160305/aecd60a6/attachment.html>
