[Qgis-user] Freezing in editing mode
DelazJ delazj at gmail.com
Thu Mar 17 02:37:50 PDT 2016
Do you have plugins installed? There are some issue reports in hub.qgis.org
that reveal that the culprit are some plugins.
Can you test in a session without plugins enabled (
http://docs.qgis.org/testing/en/docs/user_manual/introduction/getting_started.html#command-line-options
2016-03-17 10:06 GMT+01:00 massimo.figaroli <massimo.figaroli at gmail.com>:
> Goodmorning everybody!
> I'm using QGIS Wien and QGIS Pisa but I'm noticing the same problem.
> At the beginning and at the ending of the shape file editing (but also in
> the saving phase) I have a long time in which QGIS seems going to "freez".
> How can I solve this problem?
> Starting, saving, ending editing phases: more than 10 minutes
> Editing: 1 second (for example, adding a point).
> Is this depending of the directory in which shape files are stored?
> Thank you so much for helping me.
> Massimo Figaroli
> http://osgeo-org.1560.x6.nabble.com/Freezing-in-editing-mode-tp5256894.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/a28d7ab2/attachment.html>
