[Qgis-user] Freezing in editing mode
McDonaldR McDonaldR at angus.gov.uk
Thu Mar 17 03:24:05 PDT 2016
Hello,
We were having the same problems and moved quickly from Pisa (2.10) to Essen (2.14).  We also recreated our problem project from scratch in Essen and the problem disappeared.  The fix to improve the indexing on starting editing definitely improves things.
In our problem project the “freezing” while the index was built sometimes took 45 minutes to complete.  I can’t say for sure where the problem lies but the project was originally created in 2.4 and then used and saved in 2.6, 2.6.1, 2.8.1 – 7, 2.10 and 2.12. Maybe something was left in the project file from an older version of QGIS?  The move to 2.14 definitely fixed the problem though.
This was the issue report: http://hub.qgis.org/issues/12578
Ross
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of DelazJ
Sent: 17 March 2016 09:38
To: massimo.figaroli
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Freezing in editing mode
Do you have plugins installed? There are some issue reports in hub.qgis.org<http://hub.qgis.org> that reveal that the culprit are some plugins.
Can you test in a session without plugins enabled (http://docs.qgis.org/testing/en/docs/user_manual/introduction/getting_started.html#command-line-options)?
2016-03-17 10:06 GMT+01:00 massimo.figaroli <massimo.figaroli at gmail.com<mailto:massimo.figaroli at gmail.com>>:
Goodmorning everybody!
I'm using QGIS Wien and QGIS Pisa but I'm noticing the same problem.
At the beginning and at the ending of the shape file editing (but also in
the saving phase) I have a long time in which QGIS seems going to "freez".
How can I solve this problem?
Starting, saving, ending editing phases: more than 10 minutes
Editing: 1 second (for example, adding a point).
Is this depending of the directory in which shape files are stored?
Thank you so much for helping me.
Massimo Figaroli
View this message in context: http://osgeo-org.1560.x6.nabble.com/Freezing-in-editing-mode-tp5256894.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/da8970d3/attachment.html>
