[Qgis-user] QGIS Server - Export to PDF - Legend
Nicolas Boisteault
boisteault at observatoire-environnement.org
Tue May 3 02:08:47 PDT 2016
It seems like a bug. I guess Qgis Server can't merge WMS legends with
other layer's legend.
Nicolas BOISTEAULT
Développeur Web
Observatoire Régional de l'Environnement
Téléport 4 Antarès - BP 50163 - 86962 Futuroscope Chasseneuil Cedex
Tél : 05 49 49 71 18
Le 03/05/2016 10:47, Burghardt.Scholle at stadt.wolfsburg.de a écrit :
> Hi all,
> my System: Ubuntu 14.04, qgis-server 2.14.1 / 2.14.2
> My QGIS project contains a wms layer from UMN mapserver and different shapefiles (Polygon, Line, Point). My print template contains the map and a legend for the shapefiles. If I turn on the wms layer, the export to PDF does not work. I get an Apache 500-error. If I turn off the wms layer, the export to PDF works fine.
> Well, if I now turn on the wms layer and remove the legend only for the shapefiles with line- and point-geometry from the print template, the export to PDF works fine also. The legend of shapefiles with polygons is always exported to PDF. Is this a bug? Can anyone help me?
> BTW: I tried different wms layer and had always the same problem.
> Thanks in advance and best regards
> Burghardt
> Stadt Wolfsburg
> Geschäftsbereich IT - 15-3 GIS
> Rathaus E, Zi. E403, Porschestraße 47A, D-38440 Wolfsburg
> Tel +49 5361 28-2531
> Fax +49 5361 28-1765
> mailto:burghardt.scholle at stadt.wolfsburg.de
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
