[Qgis-user] QGIS Server - Export to PDF - Legend
Burghardt.Scholle at stadt.wolfsburg.de Burghardt.Scholle at stadt.wolfsburg.de
Tue May 3 03:40:41 PDT 2016
Hi ,
I don't display the legend of the WMS. A merge of different legends between WMS and other layer's does not take place in my case.
Greetings
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Nicolas Boisteault
> Gesendet: Dienstag, 3. Mai 2016 11:09
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] QGIS Server - Export to PDF - Legend
> It seems like a bug. I guess Qgis Server can't merge WMS legends with other
> layer's legend.
> Nicolas BOISTEAULT
> Développeur Web
> Observatoire Régional de l'Environnement Téléport 4 Antarès - BP 50163 -
> 86962 Futuroscope Chasseneuil Cedex Tél : 05 49 49 71 18 Le 03/05/2016
> 10:47, Burghardt.Scholle at stadt.wolfsburg.de a écrit :
> > Hi all,
> > my System: Ubuntu 14.04, qgis-server 2.14.1 / 2.14.2
> > My QGIS project contains a wms layer from UMN mapserver and different
> shapefiles (Polygon, Line, Point). My print template contains the map and a
> legend for the shapefiles. If I turn on the wms layer, the export to PDF does
> not work. I get an Apache 500-error. If I turn off the wms layer, the export to
> PDF works fine.
> > Well, if I now turn on the wms layer and remove the legend only for the
> shapefiles with line- and point-geometry from the print template, the export
> to PDF works fine also. The legend of shapefiles with polygons is always
> exported to PDF. Is this a bug? Can anyone help me?
> > BTW: I tried different wms layer and had always the same problem.
> > Thanks in advance and best regards
> > Burghardt
> > Stadt Wolfsburg
> > Geschäftsbereich IT - 15-3 GIS
> > Rathaus E, Zi. E403, Porschestraße 47A, D-38440 Wolfsburg Tel +49 5361
> > 28-2531 Fax +49 5361 28-1765
> > mailto:burghardt.scholle at stadt.wolfsburg.de
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
