[Qgis-user] QGIS Server - Export to PDF - Legend
Burghardt.Scholle at stadt.wolfsburg.de
Sun May 8 23:38:25 PDT 2016
Hello,
I created a bug report for this issue: http://hub.qgis.org/issues/14790
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Gesendet: Dienstag, 3. Mai 2016 12:41
> An: boisteault at observatoire-environnement.org; qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] QGIS Server - Export to PDF - Legend
> Hi ,
> I don't display the legend of the WMS. A merge of different legends
> between WMS and other layer's does not take place in my case.
> Greetings
> Burghardt
> > von Nicolas Boisteault
> > Gesendet: Dienstag, 3. Mai 2016 11:09
> > An: qgis-user at lists.osgeo.org
> > It seems like a bug. I guess Qgis Server can't merge WMS legends with
> > other layer's legend.
> > Nicolas BOISTEAULT
> > Développeur Web
> > Observatoire Régional de l'Environnement Téléport 4 Antarès - BP 50163
> > 86962 Futuroscope Chasseneuil Cedex Tél : 05 49 49 71 18 Le 03/05/2016
> > 10:47, Burghardt.Scholle at stadt.wolfsburg.de a écrit :
> > > Hi all,
> > > my System: Ubuntu 14.04, qgis-server 2.14.1 / 2.14.2
> > > My QGIS project contains a wms layer from UMN mapserver and
> > > different
> > shapefiles (Polygon, Line, Point). My print template contains the map
> > and a legend for the shapefiles. If I turn on the wms layer, the
> > export to PDF does not work. I get an Apache 500-error. If I turn off
> > the wms layer, the export to PDF works fine.
> > > Well, if I now turn on the wms layer and remove the legend only for
> > > the
> > shapefiles with line- and point-geometry from the print template, the
> > export to PDF works fine also. The legend of shapefiles with polygons
> > is always exported to PDF. Is this a bug? Can anyone help me?
> > > BTW: I tried different wms layer and had always the same problem.
> > > Thanks in advance and best regards
> > > Burghardt
> > > Stadt Wolfsburg
> > > Geschäftsbereich IT - 15-3 GIS
> > > Rathaus E, Zi. E403, Porschestraße 47A, D-38440 Wolfsburg Tel +49
> > > 5361
> > > 28-2531 Fax +49 5361 28-1765
> > > mailto:burghardt.scholle at stadt.wolfsburg.de
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
