[Qgis-user] Polygon merge/divide problem
Sheikh Salman Ahmad salman__ at msn.com
Wed May 4 23:09:05 PDT 2016
Hello
Kindly send me the shape file. after using it i will be able to tell wether i will be able to be any hello or not.
Regards
Sheikh Salman Ahmad
Date: Wed, 4 May 2016 21:33:27 +0200
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Polygon merge/divide problem
Hello everyone. I'm having problems digitalising a map of zones in a nature reserve. I have one very large complex polygon which I can't either divide or merge with other polygons. I have run a validity test and corrected the couple of errors it found, but still no luck. When I try and divide it, I'm told it still has errors and I need to repair it first. When I try to merge it, whatever polygon I try and merge with it is simply deleted!Anyone any ideas of what I could try? I'm on Windows 8.1 and I've tried both QGIS 2.8.1 and 2.14.1.Many thanks, Sarah.
Sarah Greggimmagini - parole - territorio - natura Web: www.lynkos.net
Qgis-user mailing list
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160505/e6537290/attachment.html>
