[Qgis-user] Polygon merge/divide problem
Sarah Gregg lynkosmail at gmail.com
Wed May 4 23:46:43 PDT 2016
Thanks to those of you who have written to me in private asking for a copy
of the shape. Sorry, I should have thought of it before. You can download
it here: http://www.lynkos.net/boxfile/Shape-zoning.zip .
The polygon which is behaving badly is ID 7 with zone code ERR. Most
importantly I'm trying to merge it with the adjacent polygon 44, but in the
future, I also need to be able to divide it in various points and merge it
with other polygons which I will be adding. Many thanks in advance, Sarah.
2016-05-05 8:09 GMT+02:00 Sheikh Salman Ahmad <salman__ at msn.com>:
> Hello
> Kindly send me the shape file. after using it i will be able to tell
> wether i will be able to be any hello or not.
> Regards
> Sheikh Salman Ahmad
> From: lynkosmail at gmail.com
> Date: Wed, 4 May 2016 21:33:27 +0200
> To: Qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Polygon merge/divide problem
> Hello everyone. I'm having problems digitalising a map of zones in a
> nature reserve. I have one very large complex polygon which I can't either
> divide or merge with other polygons. I have run a validity test and
> corrected the couple of errors it found, but still no luck.
> When I try and divide it, I'm told it still has errors and I need to
> repair it first. When I try to merge it, whatever polygon I try and merge
> with it is simply deleted!
> Anyone any ideas of what I could try? I'm on Windows 8.1 and I've tried
> both QGIS 2.8.1 and 2.14.1.
> Many thanks, Sarah.
> *Sarah Gregg*
> immagini - parole - territorio - natura
> Web: www.lynkos.net <http://ww.lynkos.net/>
> _______________________________________________ Qgis-user mailing list
> Qgis-user at lists.osgeo.org List info:
> http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160505/f7957063/attachment.html>
