[Qgis-user] Polygon merge/divide problem
Sarah Gregg lynkosmail at gmail.com
Thu May 5 22:41:05 PDT 2016
Just to let you all know, I spent most of yesterday trying to sort out the
shapefile following the various suggestions sent to me by mail, but nothing
doing. In the end I have decided that the only way ahead is to
redigitalise. Thanks to all of you, Sarah.
2016-05-05 8:46 GMT+02:00 Sarah Gregg <lynkosmail at gmail.com>:
> Thanks to those of you who have written to me in private asking for a copy
> of the shape. Sorry, I should have thought of it before. You can download
> it here: http://www.lynkos.net/boxfile/Shape-zoning.zip .
> The polygon which is behaving badly is ID 7 with zone code ERR. Most
> importantly I'm trying to merge it with the adjacent polygon 44, but in the
> future, I also need to be able to divide it in various points and merge it
> with other polygons which I will be adding. Many thanks in advance, Sarah.
> 2016-05-05 8:09 GMT+02:00 Sheikh Salman Ahmad <salman__ at msn.com>:
>> Hello
>> Kindly send me the shape file. after using it i will be able to tell
>> wether i will be able to be any hello or not.
>> Regards
>> Sheikh Salman Ahmad
>> From: lynkosmail at gmail.com
>> Date: Wed, 4 May 2016 21:33:27 +0200
>> To: Qgis-user at lists.osgeo.org
>> Subject: [Qgis-user] Polygon merge/divide problem
>> Hello everyone. I'm having problems digitalising a map of zones in a
>> nature reserve. I have one very large complex polygon which I can't either
>> divide or merge with other polygons. I have run a validity test and
>> corrected the couple of errors it found, but still no luck.
>> When I try and divide it, I'm told it still has errors and I need to
>> repair it first. When I try to merge it, whatever polygon I try and merge
>> with it is simply deleted!
>> Anyone any ideas of what I could try? I'm on Windows 8.1 and I've tried
>> both QGIS 2.8.1 and 2.14.1.
>> Many thanks, Sarah.
>> *Sarah Gregg*
>> immagini - parole - territorio - natura
>> Web: www.lynkos.net <http://ww.lynkos.net/>
>> _______________________________________________ Qgis-user mailing list
>> Qgis-user at lists.osgeo.org List info:
>> http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160506/ecc7d452/attachment.html>
