[Qgis-user] Connect lines in Geoserver
emmexx emmexx at tiscalinet.it
Tue May 10 01:40:05 PDT 2016
I was trying to update a lines layer from geoserver (WFS) to add a new
line and to connect it to other lines.
I remember I did that in the past but I'm not sure now.
I enable snapping, create the line, add the points and snap the starting
and ending nodes to other lines, then I save.
If I try to move the connecting node in qgis, both lines move.
But when I check on geoserver the 2 lines are not connected (I use that
layer for routing). I exported the layer data to josm and even there I
see that the lines are not connected.
What am I doing wrong?
Thank you
	maxx
