[Qgis-user] QGIS closes unexpectedly
Randal Hale
rjhale at northrivergeographic.com
Wed May 18 09:53:10 PDT 2016
Excellent. I *think* it's still being developed - but I ultimately have
no idea. Maybe someone will weigh in with an answer.
I'm glad its working for you! So I sorta helped - which is better than
not helping.
Regards from the United States (Chattanooga TN)
Good Luck!
Randy
On 05/18/2016 12:47 PM, Carlos Cerdán wrote:
> Thank you Randal!
> It was not individual rendering. You gave me a great clue: It was the
> way how QGIS tries to do rendering: using many cores. So, I turned off
> this option (Configuration --> Options --> Rendering --> Render layers
> in parallel using many CPU cores ).
> Now QGIS is working fine.
> So, Is still multi-cores usange under development? (My processor is
> Intel® Core™ i7-3770 CPU @ 3.40GHz × 8 )
> Regards from Peru
> Carlos Cerdan
> 2016-05-18 8:34 GMT-05:00 Randal Hale <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>>:
> See if this fixes it - https://hub.qgis.org/issues/12577
> Right click on your vector file. Go to Properties -> Rendering ->
> Turn off simplify Geometry.
> It appears to be an issue with the way QGIS is handling that
> projection.
> I hope that works!
> On 05/11/2016 10:34 AM, Carlos Cerdán wrote:
>> Thank you Randal.
>> No, I'm not applying SVG styles. It happens even with a layer
>> with single style.
>> I've tried running QGIS with no plugins, or with different
>> layers, but I got same behavior. In Windows it's ok.
>> Carlos
>> 2016-05-11 8:26 GMT-05:00 Randal Hale
>> Are you applying a SVG Style?
>> I'm running Ubuntu 16.04 (xubuntu) with the same repo and
>> it's not Crashing - BUT - it did when applying an SVG style
>> at 2.14.0 and 2.14.1 - but I think that issue is fixed now
>> (or it has stopped for me).
>> Randy
>> On 05/11/2016 09:20 AM, Carlos Cerdán wrote:
>>> Sorry, i mistook data. It's QGIS 2.14.2 and Ubuntu 16.04
>>> But I'm in same trouble: QGIS closes unexpectedly specially
>>> (but not always) when I apply a style
>>> Running from terminal, when it happens, I get this message:
>>> /ERROR 6: EPSG PCS/GCS code 53009 not found in EPSG support
>>> files. Is this a valid EPSG coordinate system?
>>> Violación de segmento/ (Segmentation fault?)
>>> My QGIS repo is http://qgis.org/debian xenial main
>>> Please some idea about what it's wrong? It's a 2.14.2 QGIS bug?
>>> Carlos Cerdán
>>> 2016-05-09 12:27 GMT-05:00 Carlos Cerdán
>>> <sig.upagu at gmail.com <mailto:sig.upagu at gmail.com>>:
>>> Hi there:
>>> QGIS 2.14.3 - Ubuntu 16.04
>>> My QGIS installation begun to fail since I've updated to
>>> 2.14.3. It closes unexpectedly. I have not found a
>>> patron, sometimes it's in a zoom, changing style, trying
>>> to open a layer, etc.
>>> Someone has similar trouble?
>>> Before update, all was fine. Is it something in new
>>> packets? Perhaps it's a plugin?. Compiz effects?
>>> Ubuntu's classic desktop?
>>> Please if some has an idea, it's welcome.
>>> Carlos Cerdán
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611rjhale at northrivergeographic.com
>> twitter:rjhalehttp://about.me/rjhale
>> http://www.northrivergeographic.com/introduction-to-quantum-gis
>> https://www.facebook.com/NRGSInc
> Randal Hale
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160518/fb097b85/attachment.html>
