[Qgis-user] QGIS closes unexpectedly
Carlos Cerdán sig.upagu at gmail.com
Wed May 18 09:47:07 PDT 2016
Thank you Randal!
It was not individual rendering. You gave me a great clue: It was the way
how QGIS tries to do rendering: using many cores. So, I turned off this
option (Configuration --> Options --> Rendering --> Render layers in
parallel using many CPU cores ).
Now QGIS is working fine.
So, Is still multi-cores usange under development?  (My processor is Intel®
Core™ i7-3770 CPU @ 3.40GHz × 8 )
Regards from Peru
Carlos Cerdan
2016-05-18 8:34 GMT-05:00 Randal Hale <rjhale at northrivergeographic.com>:
> See if this fixes it - https://hub.qgis.org/issues/12577
> Right click on your vector file. Go to Properties -> Rendering -> Turn off
> simplify Geometry.
> It appears to be an issue with the way QGIS is handling that projection.
> I hope that works!
> On 05/11/2016 10:34 AM, Carlos Cerdán wrote:
> Thank you Randal.
> No, I'm not applying SVG styles. It happens even with a layer with single
> style.
> I've tried running QGIS with no plugins, or with different layers, but I
> got same behavior. In Windows it's ok.
> Carlos
> 2016-05-11 8:26 GMT-05:00 Randal Hale <rjhale at northrivergeographic.com>:
>> Are you applying a SVG Style?
>> I'm running Ubuntu 16.04 (xubuntu) with the same repo and it's not
>> Crashing - BUT - it did when applying an SVG style at 2.14.0 and 2.14.1 -
>> but I think that issue is fixed now (or it has stopped for me).
>> Randy
>> On 05/11/2016 09:20 AM, Carlos Cerdán wrote:
>> Sorry, i mistook data. It's QGIS 2.14.2 and Ubuntu 16.04
>> But I'm in same trouble: QGIS closes unexpectedly specially (but not
>> always) when I apply a style
>> Running from terminal, when it happens, I get this message:
>> *ERROR 6: EPSG PCS/GCS code 53009 not found in EPSG support files.  Is
>> this a valid EPSG coordinate system? Violación de segmento*
>> (Segmentation fault?)
>> My QGIS repo is http://qgis.org/debian xenial main
>> Please some idea about what it's wrong? It's a 2.14.2 QGIS bug?
>> Carlos Cerdán
>> 2016-05-09 12:27 GMT-05:00 Carlos Cerdán < <sig.upagu at gmail.com>
>> sig.upagu at gmail.com>:
>>> Hi there:
>>> QGIS 2.14.3 - Ubuntu 16.04
>>> My QGIS installation begun to fail since I've updated to 2.14.3. It
>>> closes unexpectedly. I have not found a patron, sometimes it's in a zoom,
>>> changing style, trying to open a layer, etc.
>>> Someone has similar trouble?
>>> Before update, all was fine. Is it something in new packets? Perhaps
>>> it's a plugin?. Compiz effects? Ubuntu's classic desktop?
>>> Please if some has an idea, it's welcome.
>>> Carlos Cerdán
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale
>> North River Geographic Systems, Inchttp://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale     http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gishttps://www.facebook.com/NRGSInc
> Randal Hale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160518/ae9bb7ea/attachment.html>
