[Qgis-user] qgis 2.18.3 not installing on win 10
Martin Bain Martin.Bain at lismore.nsw.gov.au
Sun Feb 26 17:25:17 PST 2017
Is there any chance it's the 32 bit OSGEO4W running on a 64 bit Windows?
I got a similar error trying to run a portable install on USB of 2.18, 32 bit on 64 bit Win 7 (2.14 ran just fine)
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Michael.Dodd
Sent: Monday, 27 February 2017 9:01 AM
To: Andre Joost <andre+joost at nurfuerspam.de>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] qgis 2.18.3 not installing on win 10
I tried uninstalling and installing again using the stand alone installer.  This gave the same error so I uninstalled it.
Then I tried the OSGEO4W installer but it did not install exactly where I asked it to, instead it made its own directory on Y (Y:\osgeo_download). It did start up once but after that it failed to start and instead gave the same error about missing .dll's even though they were present.  I think I had a problem similar to this several qgis versions ago but it was then resolved, now the issue seems to be back.
This is the \QGIS 2.18\bin\qgis.bat file:
@echo off
call "%~dp0\o4w_env.bat"
@echo off
path %OSGEO4W_ROOT%\apps\qgis\bin;%PATH%
set QGIS_PREFIX_PATH=%OSGEO4W_ROOT:\=/%/apps/qgis
set GDAL_FILENAME_IS_UTF8=YES
rem Set VSI cache to be used as buffer, see #6448
set VSI_CACHE=TRUE
set VSI_CACHE_SIZE=1000000
set QT_PLUGIN_PATH=%OSGEO4W_ROOT%\apps\qgis\qtplugins;%OSGEO4W_ROOT%\apps\qt4\plugins
start "QGIS" /B "%OSGEO4W_ROOT%"\bin\qgis-bin.exe %*
and this is the directory where the relevant .dll's are Y:\osgeo_download\apps\qgis\bin
but it says they are missing even though they are present in this directory.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> on behalf of Andre Joost <andre+joost at nurfuerspam.de<mailto:andre+joost at nurfuerspam.de>>
Sent: 26 February 2017 16:23:38
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Am 25.02.2017 um 21:58 schrieb Michael.Dodd:
> Have been using qgis for years.  Just uninstalled 2.14 and installed
> 2.18.3 but it refused to start saying that qgis_app.dll,
> qgis_core.dll and qgis_gui.dll are all missing.
> Infact they are not missing, they are all present.  However it seems
> to be looking in the wrong place, think similar problem has occurred
> with one or two previous versions.  I am NOT installing on c: drive
> as it has little space but instead installing on y: drive.  This
> worked fine for version 2.14 and various other programs but with
> version 2.18.3 it does not work.
You could try the OSGEO4W installer. It lets you choose the root
directory where everything is installed to.
Or have a look at \QGIS 2.18\bin\qgis.bat and o4w_env.bat. The variable
OSGEO4W_ROOT might be set wrongly. You get it when you type set inside
the OSGEO4W Shell. Override the definition if necessary.
HTH
André Joost
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170227/4680a4c9/attachment.html>
