[Qgis-user] QGIS 3.4.2 still very slow to work in Windows 10
Nyall Dawson nyall.dawson at gmail.com
Mon Dec 17 14:46:40 PST 2018
On Mon, 17 Dec 2018 at 18:49, David Addy <davesgrandad at gmail.com> wrote:
> Hi Nyall,
> Thanks for your additional comment.
> When I was autoloading my most recent project at startup QGIS was taking up
> to a minute to open itself and load the project. Other saves and actions
> like opening a layer attribute table were also very slow.
> After changing my settings to open with a new project (ie a blank project)
> QGIS was opening as normal. Then loading the old project also was as fast as
> it should be.
> However, after editing some polygons,  when I come to save the changes I am
> still getting a long pause when nothing happens, then I get "QGIS is not
> responding",  then it comes back to life again and finishes the save.
> So changing the setting vastly improved startup, but seems to have not
> solved the whole problem.
Question - are your project files local? Or stored on a network drive?
If so, does it make any difference if you use locally stored projects?
Nyall
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
