[Qgis-user] QGIS3 location error
Richard Duivenvoorde rdmailings at duif.net
Fri Mar 9 10:07:42 PST 2018
Which version of proj are you using? See the about box of QGIS.
If it is 500, you hit a proj issue, see this thread
https://lists.osgeo.org/pipermail/qgis-developer/2018-March/052501.html
(or in this list read msgs with subject "proj5 and epsg:3857")
If you have 49* it is another problem.
Regards,
Richard
On 09-03-18 18:47, Adam Dershowitz wrote:
> I have a project that I created and have worked with in QGIS2.  I just
> tried it in QGIS3, and one of the layers is showing in the wrong
> location.  In both cases they show a CRS definition of "+proj=merc
> +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
> +units=m +nadgrids=@null +wktext +no_defs"
> After doing some testing, and creating a new project, it seems that
> there is a single layer that is offset in QGIS3, from the correct
> location, by about 500m West and about 20,000m North.
> The layer is a JP2 imagery layer, that I downloaded from this link:
> https://www.sciencebase.gov/catalog/item/58281f9fe4b01fad870f045f
> And, here is the information about it:
> https://www.sciencebase.gov/catalog/file/get/58281f9fe4b01fad870f045f?f=__disk__76%2F45%2F79%2F7645799634b35663c92271129192d7ff9c4204e0&transform=1&allowOpen=true
> <https://www.sciencebase.gov/catalog/file/get/58281f9fe4b01fad870f045f?f=__disk__76/45/79/7645799634b35663c92271129192d7ff9c4204e0&transform=1&allowOpen=true>
> As one example, if I use an NAD83 CRS, it shows up as being from
> approximately 36.12deg N to about 36.18deg N.  But, according to the
> link above, the actual bounding coordinates should be 35.9375 to 36.0000.
> Any idea why this won’t show up in the correct location, or what I can
> do about it?
> I’m using qgis 3.0.0_1 on a Mac that I installed using Macports.
> Thanks,
> --Adam
> Qgis-user mailing list
