[Qgis-user] clipping csv data to shapefile
Steve Research
stevesteveresearch at gmail.com
Tue Mar 27 06:04:36 PDT 2018
Thanks Alexandre,
I had done this for the Europe layer but did it again for both the data and coast layers.
Removed all other layers and ran the clip again.
That has worked perfectly.
Cheers
Steve
> On 27 Mar 2018, at 08:10, Alexandre Neto <senhor.neto at gmail.com> wrote:
> In that case, your Europe shape was not well projected. Setting the CRS at the project is not enough.
> Set it back to the original CRS, then use the save as tool on the layer to reproject to WGS84.
> If you are in QGIS 3, I think you no longer need to use the same CRS on both layers.
> A ter, 27/03/2018, 07:54, Steve Research <stevesteveresearch at gmail.com> escreveu:
>> Thanks Alexandre,
>> I have tried that but it is odd. I have plant world distribution data (lat and long) in a csv which I have as a WGS84 vector layer. I have a European shp file which is converted to WGS84. If I clip the world data layer to the Europe shp I end up with a new, but blank, vector layer.
>> Cheers
>> Steve
>>> On 26 Mar 2018, at 22:25, Alexandre Neto <senhor.neto at gmail.com> wrote:
>>> Hi Steve,
>>> In the processing toolbox search for clip.
>>> set the csv as the input layer, and the world ?countries? shapefile as clip layer.
>>> Hope it helps
>>> Steve Research <stevesteveresearch at gmail.com> escreveu no dia segunda, 26/03/2018 às 21:31:
>>>> I have some plants distribution data (from GBIF) in CSV format.
>>>> I added this to my world map shapefile (Layer\Add Layer\Add Delimited Text layer).
>>>> Some records are outside of the coastline.
>>>> How can I clip this CSV data to the coastline?
>>>> Regards,
>>>> Steve
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180327/c7b92bee/attachment.html>
