[Qgis-user] Auxiliary storage: not editable if layer is not editable
Paul Blottiere blottiere.paul at gmail.com
Tue Jun 25 05:25:50 PDT 2019
Hi Bernhard,
> I was under the impression that the auxiliary storage was designed to
cover exactly this kind of situation.
Indeed you're right.
Actually you just have to use the "Move Label" map tool directly on labels,
and their positions will be stored in auxiliary storage automatically. If
you want to manually create corresponding fields, you have to use the
"Store Data in the project" button in data defined menu.
Paul
Le lun. 24 juin 2019 à 10:07, Bernhard Ströbl <bernhard.stroebl at jena.de> a
écrit :
> Hi all,
> I have a PostGIS relation that is not editable in QGIS (user has only
> SELECT rights). I created a field in the auxiliary storage to insert
> positioning information. I cannot edit this field because "toggle
> editing" is disabled. I was under the impression that the auxiliary
> storage was designed to cover exactly this kind of situation. Anything I
> am missing?
> BTW I am using QGIS 3.4.8.
> Bernhard
> __________ Information from ESET Mail Security, version of virus signature
> database 19573 (20190624) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190625/9eadedcc/attachment.html>
