[Qgis-user] Auxiliary storage: not editable if layer is not editable
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Jun 25 05:34:07 PDT 2019
Hi Paul,
thanks for your feedback. I figured out that the label-positioning
buttons do indeed work but I was after setting an x-y offset for a point
symbol.
I created a ticket meanwhile:
https://github.com/qgis/QGIS/issues/30376
Bernhard
Am 25.06.2019 um 14:25 schrieb Paul Blottiere:
> Hi Bernhard,
>  > I was under the impression that the auxiliary storage was designed to
> cover exactly this kind of situation.
> Indeed you're right.
> Actually you just have to use the "Move Label" map tool directly on
> labels, and their positions will be stored in auxiliary storage
> automatically. If you want to manually create corresponding fields, you
> have to use the "Store Data in the project" button in data defined menu.
> Paul
> Le lun. 24 juin 2019 à 10:07, Bernhard Ströbl <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>> a écrit :
>     Hi all,
>     I have a PostGIS relation that is not editable in QGIS (user has only
>     SELECT rights). I created a field in the auxiliary storage to insert
>     positioning information. I cannot edit this field because "toggle
>     editing" is disabled. I was under the impression that the auxiliary
>     storage was designed to cover exactly this kind of situation.
>     Anything I
>     am missing?
>     BTW I am using QGIS 3.4.8.
>     Bernhard
>     __________ Information from ESET Mail Security, version of virus
>     signature database 19573 (20190624) __________
>     The message was checked by ESET Mail Security.
>     http://www.eset.com
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
__________ Information from ESET Mail Security, version of virus signature database 19580 (20190625) __________
http://www.eset.com
