[Qgis-user] Updating multiple parent/child records simultaneously
Matthias Kuhn
matthias at opengis.ch
Mon Mar 16 23:57:51 PDT 2020
Hi Alexandre, Ross,
Denis recently wrote a plugin that also handles batch management of
relations. https://github.com/opengisch/qgis-relation-batchinsert
He is not reading the qgis user list but would be happy to share his
thoughts if you get in touch with him.
Best regards
Matthias
On 3/17/20 2:19 AM, Alexandre Neto wrote:
> Hi,
> I have been looking for the same myself. I think I would be able to
> create a "replicate relations" plugin but I am missing a step... this one:
> https://gis.stackexchange.com/questions/353309/open-feature-form-in-multi-edit-mode-using-pyqgis
> The idea would be to, for each selected feature, create an row in the
> related table, then open them all with the multi editing form.
> Alexandre Neto
> On Wed, Oct 2, 2019 at 11:35 AM McDonaldR <McDonaldR at angus.gov.uk
> <mailto:McDonaldR at angus.gov.uk>> wrote:
> Hi list,
> I’ve got a project set up in QGIS 3.4.x with a parent polygon
> layer and a child attribute layer. Each site polygon represents a
> piece of land and can have multiple tasks associated with it
> (grass cutting, weeding, pruning, etc.). Sites can be made up of
> multiple polygons.
> With relations set up in the project it is easy to select a
> polygon feature and update attributes. It is easy to add or edit
> associated tasks. See screenshots below. With multiple site
> polygons selected I can use the “modify selected attributes
> simultaneously” to update information.
> I need to find a way to be able to select site polygons and add
> the same associated task to each one. For example, select all
> site polygons that need grass cutting task associated with them,
> assign the task and maintain the parent child relationship. It
> would be great if there was a way to do this through the form.
> One solution I have been toying with is using a SQL query to
> select the site polygons and insert into the associated tasks
> table a new record associated with each polygon. The query works
> but I need a way to tie it into the form. Anyone got any
> pointers? Some python to call the SQL and get the selected
> feature IDs from QGIS?
> Thanks
> Ross
> Screenshot 1: https://nextcloud.mixedbredie.net/s/D7DFjs2PrcnEf7t
> Screenshot 2: https://nextcloud.mixedbredie.net/s/EBzeTopsBcZBSJc
> *Ross McDonald | *Geo-evangelist | Angus Council, Digital
> Enablement and IT | Angus House, Orchardbank Business Park, Sylvie
> Way, Forfar DD8 1AT*| t: 01307 49 22 39*
> This message is strictly confidential. If you have received this
> in error, please inform the sender and remove it from your system.
> If received in error you may not copy, print, forward or use it or
> any attachment in any way. This message is not capable of creating
> a legal contract or a binding representation and does not
> represent the views of Angus Council. Emails may be monitored for
> security and network management reasons.Messages containing
> inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the
> recipient system or data on it by this message or any attachment.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200317/ae3de7d6/attachment.html>
