[Qgis-user] QFIS WFS error msg help please
Jorge Gustavo Rocha jgr at geomaster.pt
Thu Mar 19 02:00:03 PDT 2020
Hi Brent,
I would try to run some XML validator on DescribeFeatureType output to
make sure it is valid. You can use xmlstarlet for that. Please share
your DescribeFeatureType output, if not confidential.
Also check WFS version: typeName for WFS 1.1.0 and earlier and typeNames
for version 2.x.
Regards,
Jorge
On 18/03/20 22:57, Brent Wood wrote:
> Hi,
> I'm setting up mapserver to provide WFS services to be consumed by
> QGIS. The capabilities doc works fine from a browser, and connecting
> from QGIS I get the available layer listed fine, so QGIS works fine
> with the WFS to at least get the capabilities doc.
> I get an error when trying to retrieve the layer, and have found a few
> references but nothing helpful. I need help interpreting the QGIS
> error before I can attempt to fix the error in the mapfile (if there
> is one).
> Error msg: (same in QGIS 2.18, 3.4, 3.10)
> 2020-03-19T11:52:38 1 Analysis of DescribeFeatureType response failed
> for url srsname='EPSG:4326' typename='ms:Specimens'
> url='http://wellmapsrvdev.niwa.co.nz/cgi-bin/mapserv?map=/usr/lib/cgi-bin/mapfiles/specify.map'
> version='auto' table="" sql=: it is probably a schema for Complex Features
> Any advice appreciated...
> Brent Wood
> Qgis-user mailing list
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200319/7f657a42/attachment.html>
