[Qgis-user] [QGIS-Developer] Questions of a newbie starting with QGIS Server
Richard Duivenvoorde rdmailings at duif.net
Wed Apr 20 11:23:56 PDT 2022
Hi Harrissou,
I think your pretty close :-)
Some remarks from the times I installed on Windows:
- I used a vanilla apache installer from https://www.apachelounge.com/
- indeed used the httpd.conf from osgeo4w to set all paths and env vars, VERY convenient
- are you sure the Qt vs qt is an issue? Thought Windows paths were not case sensitive?
The GDAL_DATA path you will need when you use for example the ECW or other drivers
QGIS_AUTH_DB_DIR_PATH is maybe only needed when you have a project which uses authentication profiles? Others?
When you have a WMS/WFS server running normally you do not have a web app yet.
You either use the WMS of WFS as datasource in QGIS (or other clients)
or you use OpenLayer/Leaflet to create an app in a browser using javascript.
Alessandro also created a landing page for WFS3/OGC API:
https://docs.qgis.org/3.22/en/docs/server_manual/services/ogcapif.html
but I found that sometimes tricky to setup...
Maybe others can share more info/experience
Regards,
On 4/20/22 18:58, Harrissou s. via QGIS-Developer wrote:
> Hi QGISers (sorry for cross-posting)
> I'm trying to setup a QGIS Server... on Windows and I'd like to share some
> suggestions/issues I faced in the process and ultimately ask for help on a
> bigger issue.
> I'm following the QGIS documentation instructions [0] and took the
> opportunity to update the docs[1][2], given that osgeo4w provides means to
> install apache. Review welcome, thanks.
> In the docs, it is suggested to add at the end of the httpd.conf file a
> set of variables. But I notice that *most* of them are already set in the
> httpd_qgis.conf file that is #included at the end of the httpd.conf file. I
> hence ignored the addition but, Questions:
> - are the GDAL_DATA and QGIS_AUTH_DB_DIR_PATH necessary for any purpose?
> - If so, for what? And is it possible (does it make sense) to add them to the
> httpd_qgis.conf file also?
> - Issue report: I think there is a typo in the httpd_qgis.conf file
> setting PATH and QT_PLUGIN_PATH. It mentions apps/qt5/ while it should be
> apps/Qt5/ (uppercase Q).
> In my process, I didn't set the gdal or db paths above, I fixed the
> uppercase typo and when I tested I could get a reply for GetCapabilities as in
> the docs. Using the QGIS training project, I could do a GetMap which successfully returned my map canvas image. Good! My server is OP!
> Well, this is where I got lost. I thought the request would output in the
> browser some image i could zoom in, pan, maybe identify... But NO, I got a
> plain, static image. What am I supposed to do next? How can I make my
> project queryable, zoomable, pannable, anythingable... in a web browser?
> I might have overlooked, but the docs does not seem t provide any information for
> newbies like me, for the next step. Where should I look now? Your help to
> get out of this trouble would be much appreciated. Thanks.
> Regards,
> Harrissou
> [0]
> https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-windows <https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-windows>
> [1] reading:
> https://github.com/DelazJ/QGIS-Documentation/blob/installQGISServerWindows/docs/server_manual/getting_started.rst <https://github.com/DelazJ/QGIS-Documentation/blob/installQGISServerWindows/docs/server_manual/getting_started.rst>
> [2] pull-request: https://github.com/qgis/QGIS-Documentation/pull/7508 <https://github.com/qgis/QGIS-Documentation/pull/7508>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
