[Qgis-user] Adding python package dependencies to a QGIS plugin
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Thu Apr 21 04:23:02 PDT 2022
Hey Robert :)
tl;dr: Check this out ->
https://lists.osgeo.org/pipermail/qgis-developer/2022-April/064661.html
This question has been asked many times but because mailing lists are
... special ... the discussions around it are spread across tens of
messages, accessible via arcane and hard-to-navigate websites that might
not even be indexed nicely by search engines.
Anyways, just some days ago this was discussed once again on the
qgis-developer list:
In this case you are lucky that the discussion has not gone into another
month yet so you should be able to click on "Next message (by thread)"
to see the discussion bit-by-bit. I'd recommend checking the threaded
view too though
https://lists.osgeo.org/pipermail/qgis-developer/2022-April/thread.html
because someone might have decided to branch off into another thread
with a different mail subject.
If you want to reply, you cannot use your account on the qgis-user
mailing list but have to register once again.
No, I don't like mailing lists, thanks for asking! >:( ;)
Cheers, Hannes
Am 19.04.22 um 23:08 schrieb nagyrobi_r--- via Qgis-user:
> Hei everybody!
> I am trying to develop a QGIS plugin, and the plugin requires python
> modules that are not present in the basic QGIS python install. Since i
> want these packages to install for users that might wish to use the
> plugin, what method would be the correct one to install the
> dependencies? I am thinking that some users might have multiple python
> installs at once, multiple pythonpaths etc.
> 1. Method using setup.py when installing the module. But how would
> that run? or when would it run? Very open for suggestions here.
> 2. Using subprocess with a try and except clause: prone for errors,
> since any python instance might be called :
> import sys
> import subprocess
> # implement pip as a subprocess:
> subprocess.check_call(['python', '-m', 'pip', 'install',
> '<packagename>'])
> 3. Using pip.main, which seems to warn about a deprecation
> possibilities for the future
> import pip
> pip.main(['install', package])
> Method 1 could run one time at the plugin install, whilst methods 2
> and 3 would run at every plugin load.
> How do you go about adding dependencies to your package?
> Kind regards,
> Robert Nagy
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/967e0b86/attachment.html>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/967e0b86/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/967e0b86/attachment.sig>
