[Qgis-user] Overlapping
chris hermansen clhermansen at gmail.com
Fri Feb 11 08:58:00 PST 2022
Michael and list
On Fri, Feb 11, 2022 at 8:49 AM Michael Williamson <
michael at michaelandjane.org.uk> wrote:
> I am sure this is easy but I can’t work out which facility to use
> I have two layers. Layer A is made up of some large polygons while Layer B
> is made up of smaller polygons. The Polygons in Layer A overlap one or more
> of the polygons in layer B. In most cases the overlap is 100% but there are
> a few cases where the overlap is less than that.
> Layer B contains population and other data as numerical attributes and I
> want to populate corresponding attributes in layer A with the weighted
> total of the attributes in layer B depending on the amount of overlap.
> I have found various tools but I cannot work out which one to use. The
> ones I have found seem to do part of the job but not all of it.
> Probably you want
Vector > Geoprocessing Tools > Intersection
That will give you a new layer C with the geometric intersections of your
Layer A and Layer B.  The attribute table for Layer C will contain the
attributes of both A and B.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220211/a32554fa/attachment.html>
