[Qgis-user] GRASS r.series - ERROR: Unable to load GDAL library
Chris George cgeorge at mcmaster.ca
Fri Jul 15 04:10:45 PDT 2022
Having a similar problem I discovered that somewhere between 3.22.4 and
3.22.8 the version of GDAL used by QGIS (and supplied with it) changed
from 304 to 305.  Is this your problem?
Chris
On 7/15/2022 10:52 AM, Nelson Ribeiro via Qgis-user wrote:
> Dear list,
> I have some large raster datasets to process statistics, but it was not
> working. Time consuming aligned, reprojected, changed data type, all I
> could to try to make it work, and finally concluded, after testing with
> smaller datasets, that the problem wasn’t with the data grass r.series
> had stopped working.
> Loading resulting layers
> The following layers were not correctly generated.
> I tried uninstalling reinstalling QGIS, the problem persists.
> I’m using:
> QGIS version 3.22.8-Białowieża
> Windows 11 Home
> Version 21H2
> OS build 22000.795
> All updates.
> I had to resource to ArcMap cell statistics to do it but would like to
> solve the issue and have QGIS with complete processing tools option.
> Any suggestion? Did anyone else had this happening?
> Thank you very much!
> Nelson Ribeiro
> Qgis-user mailing list
