[Qgis-user] geolocating a list of addresses
Francesca Parente
francescaparente.rse at gmail.com
Thu Mar 3 03:51:14 PST 2022
Thanks a lot Ujaval, now I see the points displayed!
The problem is different than I though then, because it's like this new
layer has a different scale with respect to the ones I was already working
on... how can I reconcile the two, in order to see the points within the
boundaries of related polygons?
Thank you so much once again!
Francesca
Il giorno gio 3 mar 2022 alle ore 12:20 Ujaval Gandhi <
ujaval at spatialthoughts.com> ha scritto:
> Right-click the layer and select 'Zoom to Layer'. If you still do not see
> the points, it must be a problem with your CRS or the coordinates itself.
> (Make sure Longitude is X field and Latitude is Y field)
> [image: Logo] <https://spatialthoughts.com/>
> Ujaval Gandhi
> Spatial Thoughts
> mobile: +91-8095684687
> email: ujaval at spatialthoughts.com
> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
> Twitter icon] <https://twitter.com/spatialthoughts>
> On Thu, Mar 3, 2022 at 4:45 PM Francesca Parente <
> francescaparente.rse at gmail.com> wrote:
>> Hello everyone and thank you for making this mailing list available!
>> I am using QGIS 3.18 and I have a list of punctual street addresses
>> (along with their latitude/longitude data), that I would like to display
>> and analyze.
>> I've already set a project with polygon layers and related attributes, in
>> which the locations should fit.
>> I imported the addresses in this project as a delimited text layer
>> (specifying the coordinates info in the geometry definition menu), but
>> nothing happened next - other than seeing it added to the project layers'
>> list.
>> I'm not sure on how to proceed further and any advice you may have would
>> be so very much appreciated.
>> Many thanks for your time and good day to all!
>> Francesca Parente
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/0c76e47d/attachment.html>
