[Qgis-user] geolocating a list of addresses
Francesca Parente francescaparente.rse at gmail.com
Fri Mar 4 01:55:56 PST 2022
Hello again and apologies for re-posting on this same thread, I still
haven't managed to display the points within their polygons.
I checked the CRS and it's same for both layers: [image: image.png]
I believe there is an issue with the scale, which I'm not sure how to
reconcile: when I zoom on the points layer it's 1:14, while with the
polygons' I see 1:9490547.
Could you please provice any advice on how to solve this?
Thank you very much indeed for your time,
Francesca
Il giorno gio 3 mar 2022 alle ore 12:51 Francesca Parente <
francescaparente.rse at gmail.com> ha scritto:
> Thanks a lot Ujaval, now I see the points displayed!
> The problem is different than I though then, because it's like this new
> layer has a different scale with respect to the ones I was already working
> on... how can I reconcile the two, in order to see the points within the
> boundaries of related polygons?
> Thank you so much once again!
> Francesca
> Il giorno gio 3 mar 2022 alle ore 12:20 Ujaval Gandhi <
> ujaval at spatialthoughts.com> ha scritto:
>> Right-click the layer and select 'Zoom to Layer'. If you still do not see
>> the points, it must be a problem with your CRS or the coordinates itself.
>> (Make sure Longitude is X field and Latitude is Y field)
>> [image: Logo] <https://spatialthoughts.com/>
>> Ujaval Gandhi
>> Spatial Thoughts
>> mobile: +91-8095684687
>> email: ujaval at spatialthoughts.com
>> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
>> Twitter icon] <https://twitter.com/spatialthoughts>
>> On Thu, Mar 3, 2022 at 4:45 PM Francesca Parente <
>> francescaparente.rse at gmail.com> wrote:
>>> Hello everyone and thank you for making this mailing list available!
>>> I am using QGIS 3.18 and I have a list of punctual street addresses
>>> (along with their latitude/longitude data), that I would like to display
>>> and analyze.
>>> I've already set a project with polygon layers and related attributes,
>>> in which the locations should fit.
>>> I imported the addresses in this project as a delimited text layer
>>> (specifying the coordinates info in the geometry definition menu), but
>>> nothing happened next - other than seeing it added to the project layers'
>>> list.
>>> I'm not sure on how to proceed further and any advice you may have would
>>> be so very much appreciated.
>>> Many thanks for your time and good day to all!
>>> Francesca Parente
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Francesca Parente
_ SESS Euro PhD
<https://phd.uniroma1.it/web/FRANCESCA-PARENTE_nT1602922_IT.aspx> in
SocioEconomic and Statistical Studies
_ Luiss SEP <https://sep.luiss.it/> School of European Political Economy
email: francescaparente.rse at gmail.com
       parentef at luiss.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/9460e5bc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/9460e5bc/attachment-0001.png>
