[Qgis-user] geolocating a list of addresses
Ujaval Gandhi ujaval at spatialthoughts.com
Fri Mar 4 02:07:15 PST 2022
You mention your points are in Lat/Lon but your chosen CRS is UTM. That's
the mismatch.
If your point coordinates are in Latitude Longitude, choose EPSG:4326 WGS84
as your CRS when importing the CSV and it will line up.
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Fri, Mar 4, 2022 at 3:26 PM Francesca Parente <
francescaparente.rse at gmail.com> wrote:
> Hello again and apologies for re-posting on this same thread, I still
> haven't managed to display the points within their polygons.
> I checked the CRS and it's same for both layers: [image: image.png]
> I believe there is an issue with the scale, which I'm not sure how to
> reconcile: when I zoom on the points layer it's 1:14, while with the
> polygons' I see 1:9490547.
> Could you please provice any advice on how to solve this?
> Thank you very much indeed for your time,
> Francesca
> Il giorno gio 3 mar 2022 alle ore 12:51 Francesca Parente <
> francescaparente.rse at gmail.com> ha scritto:
>> Thanks a lot Ujaval, now I see the points displayed!
>> The problem is different than I though then, because it's like this new
>> layer has a different scale with respect to the ones I was already working
>> on... how can I reconcile the two, in order to see the points within the
>> boundaries of related polygons?
>> Thank you so much once again!
>> Francesca
>> Il giorno gio 3 mar 2022 alle ore 12:20 Ujaval Gandhi <
>> ujaval at spatialthoughts.com> ha scritto:
>>> Right-click the layer and select 'Zoom to Layer'. If you still do not
>>> see the points, it must be a problem with your CRS or the coordinates
>>> itself. (Make sure Longitude is X field and Latitude is Y field)
>>> Ujaval Gandhi
>>> Spatial Thoughts
>>> On Thu, Mar 3, 2022 at 4:45 PM Francesca Parente <
>>>> Hello everyone and thank you for making this mailing list available!
>>>> I am using QGIS 3.18 and I have a list of punctual street addresses
>>>> (along with their latitude/longitude data), that I would like to display
>>>> and analyze.
>>>> I've already set a project with polygon layers and related attributes,
>>>> in which the locations should fit.
>>>> I imported the addresses in this project as a delimited text layer
>>>> (specifying the coordinates info in the geometry definition menu), but
>>>> nothing happened next - other than seeing it added to the project layers'
>>>> list.
>>>> I'm not sure on how to proceed further and any advice you may have
>>>> would be so very much appreciated.
>>>> Many thanks for your time and good day to all!
>>>> Francesca Parente
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Francesca Parente
> _ SESS Euro PhD
> <https://phd.uniroma1.it/web/FRANCESCA-PARENTE_nT1602922_IT.aspx> in
> SocioEconomic and Statistical Studies
> _ Luiss SEP <https://sep.luiss.it/> School of European Political Economy
> email: francescaparente.rse at gmail.com
>        parentef at luiss.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/8dc76ae4/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/8dc76ae4/attachment.png>
