[Qgis-user] geolocating a list of addresses
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Mar 4 10:29:27 PST 2022
The problem with “scale” is actually a problem selecting the proper CRS for one of the layers. For example, if you CRS is in longitude-latitude, then coordinates in degrees could look like 55.12345, -25.12345. If you select a projected CRS for this layer, then degrees will be interpreted as meters or feet. Add a base layer (like a global map found in the quickmap plugin) select the layer and click zoom to layer. If your selected layer appear in the wrong place, then you must specify the proper CRS for that layer.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 4 mars 2022 à 05:08, Ujaval Gandhi via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> You mention your points are in Lat/Lon but your chosen CRS is UTM. That's the mismatch.
> If your point coordinates are in Latitude Longitude, choose EPSG:4326 WGS84 as your CRS when importing the CSV and it will line up.
> Ujaval Gandhi
> Spatial Thoughts
> mobile: +91-8095684687
> email: ujaval at spatialthoughts.com
>> On Fri, Mar 4, 2022 at 3:26 PM Francesca Parente <francescaparente.rse at gmail.com> wrote:
>> Hello again and apologies for re-posting on this same thread, I still haven't managed to display the points within their polygons.
>> I checked the CRS and it's same for both layers:
>> <image.png>
>> I believe there is an issue with the scale, which I'm not sure how to reconcile: when I zoom on the points layer it's 1:14, while with the polygons' I see 1:9490547.
>> Could you please provice any advice on how to solve this?
>> Thank you very much indeed for your time,
>> Francesca
>>> Il giorno gio 3 mar 2022 alle ore 12:51 Francesca Parente <francescaparente.rse at gmail.com> ha scritto:
>>> Thanks a lot Ujaval, now I see the points displayed!
>>> The problem is different than I though then, because it's like this new layer has a different scale with respect to the ones I was already working on... how can I reconcile the two, in order to see the points within the boundaries of related polygons?
>>> Thank you so much once again!
>>> Francesca
>>>> Il giorno gio 3 mar 2022 alle ore 12:20 Ujaval Gandhi <ujaval at spatialthoughts.com> ha scritto:
>>>> Right-click the layer and select 'Zoom to Layer'. If you still do not see the points, it must be a problem with your CRS or the coordinates itself. (Make sure Longitude is X field and Latitude is Y field)
>>>> Ujaval Gandhi
>>>> Spatial Thoughts
>>>>> On Thu, Mar 3, 2022 at 4:45 PM Francesca Parente <francescaparente.rse at gmail.com> wrote:
>>>>> Hello everyone and thank you for making this mailing list available!
>>>>> I am using QGIS 3.18 and I have a list of punctual street addresses (along with their latitude/longitude data), that I would like to display and analyze.
>>>>> I've already set a project with polygon layers and related attributes, in which the locations should fit.
>>>>> I imported the addresses in this project as a delimited text layer (specifying the coordinates info in the geometry definition menu), but nothing happened next - other than seeing it added to the project layers' list.
>>>>> I'm not sure on how to proceed further and any advice you may have would be so very much appreciated.
>>>>> Many thanks for your time and good day to all!
>>>>> Francesca Parente
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Francesca Parente
>> _ SESS Euro PhD in SocioEconomic and Statistical Studies
>> _ Luiss SEP School of European Political Economy
>> email: francescaparente.rse at gmail.com
>> parentef at luiss.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/a2c07510/attachment-0001.html>
