[Qgis-user] problem with modification of vertex
Andreas Neumann a.neumann at carto.net
Tue Nov 29 05:02:20 PST 2022
Vertex editing changed between version 2.x and 3.x. You don't drag a
vertex anymore in QGIS 3.x. You have to click in order to pick up the
vertex then move the mouse and klick again.
This change was introduced in order to allow for keyboard entries during
editing.
See also
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
Greetings,
Andreas
On 2022-11-29 13:58, Maifredi GV via Qgis-user wrote:
> Hallo,
> I have a problem with modification of vertex in Qgis Firenze 3.28.1 and
> older version ( madeira 3.4).
> With the old Pisa 2.10 it works.
> I have a mac book pro with M1 processor and IOS Ventura
> The problem is:
> I can design poligons, but if I want modify vertex it is impossible.
> I can trace a polygon.
> When I go on vertex appear a ring blu, but is impossible to pik up the
> vertex and drag it.
> If I try to modify the snap option like 20, 20 and not 12,0 that is the
> default value, it show an error message: Impossibile salvare ' * SR
> generato (+proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137
> +b=6378137 +units=m +no_defs)' -- questa definizione di stringa Proj è
> equivalente a ESRI:54004.
> Prova invece a modificare la definizione SR in un formato WKT.
> For me it is a big bib problem.
> On PC the same file works.
> Thanks for you help.
> Alessandro
> ___________________________________
> Dott. Geol. Alessandro Maifredi
> Cell. 348 2249589
> Studio Associato Maifredi
> Via dei Giustiniani 26/1
> 16123 Genova
> Geologia Verticale Studio Associato
> Via Burlando 12/1
> 16137 Genova
> **AVVERTENZE AI SENSI DEL D.LGS. 196/2003**
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i, sono da considerarsi strettamente riservate.
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio medesimo, per le finalità nello stesso indicate. Qualora lo
> riceveste senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia telefonicamente o via e-mail e di procedere alla sua
> distruzione cancellandolo dal Vostro sistema; costituisce comportamento
> contrario ai principi dettati dal Dlgs. 196/2003 trattenere il
> messaggio, divulgarlo anche in parte, distribuirlo ad altri soggetti,
> copiarlo, od utilizzarlo per finalità diverse.
> Cell. 348 2249589
> 16123 Genova
> Via Burlando 12/1
> 16137 Genova
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221129/ecf0b983/attachment.htm>
