[Qgis-user] Profile data (other than plugins) that can cause crashes?
Patrick Dunford enzedrailmaps at gmail.com
Wed Sep 21 19:48:50 PDT 2022
OK. so further testing with a new profile show the issue is still there
with the new profile. It really is a very random issue with no obvious
cause.
On 22/09/22 14:31, Patrick Dunford wrote:
> Good day
> Since I first began to use Kubuntu 22.04 from the .0 release I started
> to see crashes on Qgis that weren't experienced on the same versions
> running on previous releases of Kubuntu (certainly the case on 20.04).
> These seem to come and go depending on some random factors, which
> makes it extremely hard to write up a meaningful bug report for the
> issue which is why so far all that has been filed is one with the
> Ubuntu project bug reporting system.
> All of these crashes occur when Qgis attempts to display a file
> operation dialog (e.g. add a layer, save a layer definition file, etc).
> Today I started to see these issues happening on a system that has
> been trouble free for weeks if not months, the crashes became very
> consistent / repetitive which had not been observed for a long time up
> to now if at all.
> I have tried a new profile and at the moment that makes the problem go
> away. However the next question would be what might be contained
> within a profile that could cause such an issue. Often it is
> considered the most likely issue in a profile is to do with installed
> plugins. In this case, both profiles contain the same plugins which
> are the 10 that are installed as core plugins (5 selected by default).
> If the issue is within a profile, it must be some other part of the
> profile.
> Is there any base of experience about other parts of a profile (such
> as user settings) which can cause issues?
> The most obvious different between profiles in this case is
> previewImages folder, however removing these images made no difference
> to the issue. It would require further testing or analysis to try to
> find out where the issue might be occurring. Nevertheless a bug report
> has been filed, attaching the old and new profiles.
> Is there any straightforward way of producing a comparison between
> different versions of the databases (which must include all the user
> settings) in a profile.
> T.I.A.
