[Qgis-user] Problems with installation QGIS Server 3.28.5 on Ubuntu 22.04.
Jürgen E. Fischer jef at norbit.de
Sat Apr 22 01:07:40 PDT 2023
Moin Günter,
On Fri, 21. Apr 2023 at 18:38:06 +0200, G. Wagner, Wagner-IT via QGIS-User wrote:
> I have problems installing QGIS Server 3.28.5 on Ubuntu 22.04. (Hetzner Cloud Server [1]):
> I proceed accordingly [2]. But with "sudo apt install qgis-server --no-install-recommends --no-install-suggests " I receive:
> gw at CAX11-2204:~$ sudo apt install qgis-server --no-install-recommends --no-install-suggests
> Reading package lists... Done
> Building dependency tree... Done
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>  python3-qgis : Depends: python3-qgis-common (= 3.22.4+dfsg-3build1) but it is not going to be installed
>  qgis-providers : Depends: qgis-providers-common (= 3.22.4+dfsg-3build1) but 1:3.28.5+36jammy is to be install
> E: Unable to correct problems, you have held broken packages.
qgis-server and python3-qgis share dependencies.  You need to upgrade
python3-qgis too or remove it.  Or remove all qgis packages before switch from
stock ubuntu packages to qgis.org packages.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230422/1f268629/attachment.sig>
More information about the QGIS-User mailing list
