[Qgis-user] Problems Initializing qgis
Richard Duivenvoorde rdmailings at duif.net
Sat Aug 26 06:08:01 PDT 2023
Hi Juan,
I would try to start with a new profile; a profile contains all your plugins, but also all your settings.
Normally (when QGIS is working fine), you create a fresh profile by going to Settings / User Profiles / New Profile
A profile is nothing more then a folder... in the QGIS profiles folder, which on WIndow you can find:
c:\Users\YOU\AppData\Roaming\QGIS\QGIS3\profiles
You could move/rename the QGIS3 folder to create a super fresh profiles folder, and see if that helps.
Another option would go to current profile, probably
c:\Users\YOU\AppData\Roaming\QGIS\QGIS3\profiles\default
and remove the one plugin that uses Google EA, and then install it from within you then started QGIS
Regards,
On 8/25/23 23:20, Juan Rafael Suárez via QGIS-User wrote:
> Good morning everybody, I am having several problems with qgis, I hope somebody may help me.
> I am working in windows 10.0 System 32.0
> I upgraded to Qgis 3.28.10
> Now I have these issues:
> When I start the program at the first time nothing happens.
> Then I start by the second time, and the the program starts, but I get this message:
> "Creation of missing tbl_srs in the private qgis.db failed
> disl I/O error"
> I click on the OK button and the program starts.
> Then at starting it appears this message:
> "This plugin uses Google Earth Engine API and it looks like it is not yet authenticated on this machine. You have to need a google account registered on Earth Engine to continue.
> Click OK to open a web browser and starts the authentication process. Or click cancel to stop the authentication process."
> I click OK but it never finishes the process, although I have an account on goggle and I work frequently with google earth. Then I cancel and returns to qgis.
> I can work on qgis, but in the moment I select any layer, and I try to go to the properties form, the program crashes, doesnot work any longer and I receive this message:
> "qgis-ltr-bin.exe is not responding"
> I dont know what is the problem.
> If somebody knows and may help me I will appreciate so much.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
