[Qgis-user] Problems Initializing qgis
Juan Rafael Suárez
juanrsuarez267 at gmail.com
Sat Aug 26 12:32:29 PDT 2023
Richard I already did what you suggested me and I got a new QGIS3 folder
and I am not getting the message related to qgis-ltr-bin.exe.
But now I have a new issue, I get this message:
"Update of view in private qgis.db failed. Disk I/O error.
Could you help me to solve this one?
Thanking in advance.
El sáb, 26 ago 2023 a las 8:44, Juan Rafael Suárez (<
juanrsuarez267 at gmail.com>) escribió:
> Thanks a lot Richard, I will try it.
> Regards.
> El sáb, 26 ago 2023 a las 8:08, Richard Duivenvoorde (<rdmailings at duif.net>)
> escribió:
>> Hi Juan,
>> I would try to start with a new profile; a profile contains all your
>> plugins, but also all your settings.
>> Normally (when QGIS is working fine), you create a fresh profile by going
>> to Settings / User Profiles / New Profile
>> A profile is nothing more then a folder... in the QGIS profiles folder,
>> which on WIndow you can find:
>> c:\Users\YOU\AppData\Roaming\QGIS\QGIS3\profiles
>> You could move/rename the QGIS3 folder to create a super fresh profiles
>> folder, and see if that helps.
>> Another option would go to current profile, probably
>> c:\Users\YOU\AppData\Roaming\QGIS\QGIS3\profiles\default
>> and remove the one plugin that uses Google EA, and then install it from
>> within you then started QGIS
>> Regards,
>> On 8/25/23 23:20, Juan Rafael Suárez via QGIS-User wrote:
>> > Good morning everybody, I am having several problems with qgis, I hope
>> somebody may help me.
>> > I am working in windows 10.0 System 32.0
>> > I upgraded to Qgis 3.28.10
>> > Now I have these issues:
>> > When I start the program at the first time nothing happens.
>> > Then I start by the second time, and the the program starts, but I get
>> this message:
>> > "Creation of missing tbl_srs in the private qgis.db failed
>> > disl I/O error"
>> > I click on the OK button and the program starts.
>> > Then at starting it appears this message:
>> > "This plugin uses Google Earth Engine API and it looks like it is not
>> yet authenticated on this machine. You have to need a google account
>> registered on Earth Engine to continue.
>> > Click OK to open a web browser and starts the authentication process.
>> Or click cancel to stop the authentication process."
>> > I click OK but it never finishes the process, although I have an
>> account on goggle and I work frequently with google earth. Then I cancel
>> and returns to qgis.
>> > I can work on qgis, but in the moment I select any layer, and I try to
>> go to the properties form, the program crashes, doesnot work any longer and
>> I receive this message:
>> > "qgis-ltr-bin.exe is not responding"
>> > I dont know what is the problem.
>> > If somebody knows and may help me I will appreciate so much.
>> > _______________________________________________
>> > QGIS-User mailing list
>> > QGIS-User at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230826/d6cdf290/attachment.htm>
More information about the QGIS-User
