[Qgis-user] QGIS attribute forms question
Andreas Neumann andreas at qgis.org
Mon Dec 4 23:19:50 PST 2023
Dear Brent,
Hm - this is not what I observe. Normally you should be able to carry over
attribute widget definitions to other layers even if the attributes don't
fully match. It would assign those who match.
Are you talking about the "drag and drop" configuration mode (there are
three different form configuration modes).
I used this all the time when I was configuring more complex projects. I
never had issues when adding or removing columns.
If this doesn't work, it should be reported as a bug with data helping to
reproduce the issue.
I am sure this can be fixed.
Andreas
On Tue, 5 Dec 2023 at 04:35, Brent Wood via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I have created some forms for data entry/edit using QGIS.
> I have successfully exported them & imported them to apply in different
> computers with QGIS.
> It can take several hours to create such a form where there are 80+
> columns in the underlying database table,
> I now have the situation where the underlying table needs columns added or
> removed.
> QGIS will not apply a saved form to a layer unless the structure is
> identical.
> How can I reuse a form for a layer representing a database table with
> (say) a single new column, by adding the new column to the form, rather
> than manually creating the whole form from scratch?
> Thanks
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI:  +64 (4) 3860529
> <https://www.niwa.co.nz>
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> *Connect with NIWA:* niwa.co.nz <https://www.niwa.co.nz> Facebook
> <https://www.facebook.com/nzniwa> LinkedIn
> <https://www.linkedin.com/company/niwa> Twitter
> <https://twitter.com/niwa_nz> Instagram
> <https://www.instagram.com/niwa_science> YouTube
> <https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A> To ensure
> compliance with legal requirements and to maintain cyber security
> standards, NIWA's IT systems are subject to ongoing monitoring, activity
> logging and auditing. This monitoring and auditing service may be provided
> by third parties. Such third parties can access information transmitted to,
> processed by and stored on NIWA's IT systems.
> Note: This email is intended solely for the use of the addressee and may
> contain information that is confidential or subject to legal professional
> privilege. If you receive this email in error please immediately notify the
> sender and delete the email.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231205/8b2f4f3c/attachment.htm>
More information about the QGIS-User mailing list
