[Qgis-user] QGIS for Windows with GSS/Kerberos/Active Directory
Tomas Pospisek
tpo2 at sourcepole.ch
Fri Feb 3 07:41:28 PST 2023
When I try to set up a connection to a Postgres/Postgis DB server with
Active Directory/Kerberos/GSS authentication the QGIS DB setup dialog
displays this message:
gssencmode value "require" invalid when GSSAPI support is not
compiled in
When I check the Postgres source code [1] I see that apparently this
gets displayed when GSS support is not compiled in.
So it seems QGIS as shipped by qgis.org does not ship with GSS support?
Is that correct?
Does anybody use QGIS on Windows with GSS? How did you do it?
I could go ahead and download the EDB Postgres ZIP [3] and exctract
libpq.dll from it and replace the libqq.dll shipped by the QGIS
installer with it, but I'm not sure if that would work at all, if that
would be robust and it'll certainly be a pain to maintain.
Any pointers/suggestions/help?
*t
[1] https://doxygen.postgresql.org/fe-connect_8c_source.html#l01357
[2] https://qgis.org/de/site/forusers/download.html#windows
[3] https://www.enterprisedb.com/downloads/postgres-postgresql-downloads
More information about the QGIS-User
